KZ400 Shift Return Spring
- Feanor_twh
20 Jun 2022 07:53 - 20 Jun 2022 07:55
Recently the gear lever went crazy, first it stopped going backwards when downshifting and then also when upshifting.
I deduced that it is the return spring and I think I am right, the problem is bringing the part from the USA to Europe.
I found this but it doesn't specify my bike (1976 KZ400-D3), however it looks identical. Could someone confirm this?
The exact model option in CMSNL is not available at the moment.
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
Last edit: 20 Jun 2022 07:55 by Feanor_twh.
Re: KZ400 Shift Return Spring
20 Jun 2022 15:41
Here is the correct part number and a Fitment chart. You can use the number to search eBay and such. I do not know if the one you found will work on your 400.
www.partzilla.com/product/kawasaki/92083...5c84e30f7a07087e340b
The following user(s) said Thank You: Feanor_twh
- Feanor_twh
20 Jun 2022 17:05
Thank you very much. I found the exact model on eBay and the shipping cost was reasonable. It's already ordered.
