1982 kz1000j rod bearings
  • aquaholic
  • aquaholic's Avatar Topic Author
  • 1981 KZ1000 J1
20 Jun 2022 06:33
#869095
I'm having a very hard time finding stock connecting rod bearings or a P/N for them. I'm splitting the case and want to replace the bearings while I'm in there. Any assistance would be appreciated.  Thanks in advance
  • zed1015
  • zed1015's Avatar
Re: 1982 kz1000j rod bearings
20 Jun 2022 06:44 - 20 Jun 2022 06:46
#869097
The crank is a pressed together roller bearing crank which is very robust and rarely needs any bearing replaced under normal use or even race conditions.
Unless you have a press and means to dismantle, reassemble and align it you will have to send it to a specialist anyway.
The little ends which i think you may be reffering to do not have any replacable bearings with the gudgeon pin running directly in the rod eye so there is nothing to replace there.
Last edit: 20 Jun 2022 06:46 by zed1015.
The following user(s) said Thank You: slayer61, aquaholic
