Compression significantly different between throttle open and closed…why?
- gd4now
- Denco where did you go?
Re: Compression significantly different between throttle open and closed…why?
17 Jun 2022 10:41
I would first attempt the compression test in the same way you did and see if you get the same results. Second I have another question, is the F1 a US market bike with a vacuum petcock? If yes then I would check the petcock for a leak in the diaphragm as have read where this can lead to a leak into the #2 carb via the vacuum hose/port into the carb and cylinder creating a flooding so to speak into that cylinder which will keep it from firing correctly.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- jekyllman
17 Jun 2022 10:59
Thanks everyone for the insights. I’ll try the wet compression test and see if that changed much.
@gd4now I do have the vacuum petcock, although I bought a cheap aftermarket one recently. I will admit that I have to run it on prime or else it doesn’t get enough fuel for the 3 working cylinders…
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
- ckahleer
17 Jun 2022 22:24I'm thinking the same thing,......or/and maybe the synchronization is not great, and the butterfly of #2 is almost closed...with not throttle, related to the others.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Warren3200gt
18 Jun 2022 04:58 - 18 Jun 2022 04:59
"Compression significanty different between throttle open and closed…why?"
Same reason it's harder to breathe through a straw than it is through a drainpipe.
Last edit: 18 Jun 2022 04:59 by Warren3200gt.
The following user(s) said Thank You: 750 R1
18 Jun 2022 06:41Is the vacuum line from the petcock connected to the problem cylinder? Perhaps the diaphragm in the petcock is leaking badly.Thanks everyone for the insights. I’ll try the wet compression test and see if that changed much.
- jekyllman
18 Jun 2022 23:51
Ok so I was about to do the wet test but I ended up with the following numbers, cold, throttle closed:
1: 135
2: 145
3: 140
4: 155
…so I figured things are good?
I then thought that maybe I should double check carb vacuum balance. Vacuum was too low (~10cmHg) so I adjusted everything up to in spec.
Still no fire in cylinder #2 and that’s while using an aux gas supply and the vacuum petcock port capped
I can’t figure this thing out
1: 135
2: 145
3: 140
4: 155
19 Jun 2022 04:57
You need three things for combustion....compression, spark and fuel. If compression is OK, and I would use the standard test with the throttle open, then check for spark. If you have spark then the problem is fuel.
- ckahleer
19 Jun 2022 09:26
I have always heard that just because a plug sparks outside an engine. does not mean it is sparking inside, under compression.
What is the best way to tell if a plug is firing?
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
19 Jun 2022 09:29Swop it with a good cylinder and see if the problem moves with itI have always heard that just because a plug sparks outside an engine. does not mean it is sparking inside, under compression.
- jekyllman
19 Jun 2022 10:06
^this I would like to know. I just switched out the ignition coil (and wires and caps) on that side hoping to resolve something. I have a hunch there still might be issues with the points/condensers
19 Jun 2022 12:12Are you absolutely sure the high tension leads are connected to the correct cylinders? One coil fires cylinders 1 & 4, while the other fires 2 & 3.^this I would like to know. I just switched out the ignition coil (and wires and caps) on that side hoping to resolve something. I have a hunch there still might be issues with the points/condensers
- jekyllman
20 Jun 2022 20:26 - 20 Jun 2022 20:27
Yeah that’s how it’s set up.
update: I’ve got 13.3V at the battery. Voltage at the ignition coil leads are both 11.7. Is that normal? That doesn’t explain why one cylinder isn’t firing but I thought they should be at or near battery voltage
edit: if both ignition coils are unplugged from their leads, they will read the correct voltage. I don’t understand why it would make a difference
Last edit: 20 Jun 2022 20:27 by jekyllman.
