New sleeves needed zr400->615cc?
- Zaddict
- Enjoying my Zaddiction!
22 May 2022 19:21
I’m prepping for a wiseco 615 engine build for my zr550. cylinder heads are few and far between. I’m thinking about buying a zr400 cylinder head from japan (there are many used ones available). Anybody know if I can bore the 400 jugs to 615cc without having to replace the sleeves? My understanding is that the zr400/zr550 engines are almost identical, other than the pistons and crankshaft.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- Daftrusty
Re: New sleeves needed zr400->615cc?
23 May 2022 04:42
I think that the Zephyr400 used smaller sleeves to keep the wall thickness as such it would dissipate heat properly. So I believe that to bore them to 550 or 615, the sleeves are removed, the block bored and the 550 sleeves are installed.
There is a zr550 cyl block on eBay right now, that might work.
Here is a Japanese blog/post that I think illustrates the 400 to 550 process. (Google translate will help)
erkkiyonaga.blog62.fc2.com/blog-entry-138.html
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
The following user(s) said Thank You: Zaddict
- Stereordinary
23 May 2022 08:59
Does this answer your question?
Haha, just kidding.
But I am curious why you would need another jug, instead of just using the one that’s already in your bike?
By the way, nice to see you both.
Haha, just kidding.
A breeze from the west.
- Zaddict
23 May 2022 19:10Ah. I think you’re right. Good to know, and good Japanese website sleuthing. Thanks!I think that the Zephyr400 used smaller sleeves to keep the wall thickness as such it would dissipate heat properly. So I believe that to bore them to 550 or 615, the sleeves are removed, the block bored and the 550 sleeves are installed.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- Zaddict
23 May 2022 19:20That’s a sweet bike.
I’m planning to build the engine over time and want to keep riding while I’m doing it, hence ordering extra parts rather than modifying my current head.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
The following user(s) said Thank You: Stereordinary
- Stereordinary
24 May 2022 08:23
Ah, makes sense. Figured that had to be why.
I wanna do the same thing, but instead of a jug I want to find a whole bike, lol.
- Zaddict
24 May 2022 17:18I actually did that - bought a parts bike thinking I would modify that engine, but the bike is in such good shape (only 10K miles and unmolested) I think I'll just keep it stock as a spare.Ah, makes sense. Figured that had to be why.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- Stereordinary
24 May 2022 17:48
Nice! I'd probably do the same thing. My current (one and only) bike (550 Zephyr) is mostly original, but after the accident I was in last year it's now a rebuilt title, so I kind of feel free to modify it tastefully as I see fit. So if I can get another bike to ride while doing the big bore kit I won't hesitate.
- Daftrusty
25 May 2022 15:46
I also found that getting spares for a zr550 was really difficult, so I bought a parts bike and upgraded my kz750 with some of it and tidied up my zr550 with the rest. I also ended up with a complete motor that only has a little over 3,000 miles on it. My spare bike parts take up more room than my actual bikes.
1990 zr550
kz750e
kz750e
