I need the WISDOM of the Old Timers but Young at Heart KZ750B
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: I need the WISDOM of the Old Timers but Young at Heart KZ750B
23 May 2022 13:36
#867599
Hi ShaneDude, I see F64 has worked his magic for you. One thing I wanted to point out was reference to the below statement from you early in the thread
Would it have mattered if the grounding bar (that runs through the coil) touched something?
The bar through the coil isn't an "earthing bar" as it isn't connected to anything. It is the core the windings are wrapped around to help get the step up in voltage required, however heat is a natural by-product of coil operation. During normal running that heat is dissipated through the mounting but if the coil is not secured it will very likely overheat which probably contributed to it's failure. (Just my opinion)
  • ShaneDude
  • ShaneDude's Avatar Topic Author
  • Banned
  • Banned
23 May 2022 14:13
#867604
Ah thanks for this. Very useful
  • ShaneDude
  • Banned
  • Banned
25 May 2022 15:50
#867685
FYI you were totally right. One of my Uncle's mechanic friends tested the coil too and said the primary wire is shot. Probably happened when it was dangling from the frame from the crap job I did with zip ties. I have the new one and I will put it on. It will be done right!
