Which replacement mufflers for a KZ1100 Spectre?
- wheelie100
16 May 2022 19:45
Thanks in advance for any help or advice. I'm based on BC, Canada.
I've recently got a 1983 KZ1100 Spectre with the original black exhaust pipes and mufflers. A Kawasaki dealership told me that the orginal pipes and mufflers are all one piece, is that right?
The mufflers have got lots of holes underneath...I'm told I need to cut them off and fit new muffflers. I like the sound of the original mufflers and therefore am trying to ensure that any replacemnt mufflers I get are true to the original.
Black mufflers seem hard to come by so I'm guessing I'll need to replace them with chrome.
3 questions I'd appreciate help with:
1. Is it OK to cutt the mufflers off and fit aftermarket ones?
2. Does anyone manufacrure black aftermarket mufflers that would fit?.
Most importantly ....3. Which brand/style of mufflers are closest sounding to the orginal?
Thanks again
Thanks again
- daveo
Re: Which replacement mufflers for a KZ1100 Spectre?
18 May 2022 11:39
View current Ebay listings below for reference:
115333616854
125248119135
115333616854
125248119135
1982 KZ1100-A2/1170 sleeper 😀
19 May 2022 06:26 - 19 May 2022 06:37
1983 KZ1000-D2 muffler diagram:
www.partzilla.com/catalog/kawasaki/motor...e-kz1100-d2/mufflers
You can cut off the old mufflers & install replacements. Here's one option but chrome:
Helix Racing Megaphone Muffler. Emgo probably has something similar.
www.helixracingproducts.com/bell-shape-megaphone
vern650's motorcycle w aftermarket Dunstall replicas (cone).
Last edit: 19 May 2022 06:37 by martin_csr.
- wheelie100
20 May 2022 17:45
Many thanks @Daveo appreiate your help. The header pipes are still good jso just trying to find aftermarket mufflers if possible, but if not these look great, thanks again.
- wheelie100
20 May 2022 17:49
Thanks for the info @Martin_CSR The left muffler on my original pipes has an indent for the centre stand on the left hand muffler. Do you know if the Helix or Emgo will still fit or will they force to centre stand to be pushed out?
Thanks again
Thanks again
21 May 2022 05:09 - 21 May 2022 05:17
That's probably going to be a problem. I don't think there are any aftermarket mufflers w an indent. Some guys install a homemade stop on the center stand to keep it from banging the muffler, but it doesn't look right IMHO & not sure if the stand step could contact the pavement on sharp turns.
Probably the best option would be to get a used LH muffler. If not from a Spectre 1100, then perhaps from a different 1000/1100. or maybe from a Spectre 750 or some other model. ??? On some shaft drive models, the muffler is clamped in place from the factory. I don't know what effect a muffler from a smaller motorcycle will have on how your motorcycle runs.
Last edit: 21 May 2022 05:17 by martin_csr.
21 May 2022 08:50
Where in BC? There are a few of us here. I'm in Chase.
- daveo
22 May 2022 09:28In 2012 I installed a shiny new V&H header, since there was no good used oem alternative available at the time.Thanks for the info @Martin_CSR The left muffler on my original pipes has an indent for the centre stand on the left hand muffler. Do you know if the Helix or Emgo will still fit or will they force to centre stand to be pushed out?
Thanks again
I kept the center-stand on for a while, but eventually removed it completely. Only use it when needed to service the bike, since it only takes a minute to thread the bolts in far enough to get the job done. Quick, easy, and gone!
- wheelie100
25 May 2022 01:11 - 25 May 2022 01:13
Thanks again Martin_CSR for that. I'm trying to work out which other variants' mufflers would fit. Someone said the A2 pipes won't.
Last edit: 25 May 2022 01:13 by wheelie100.
- wheelie100
25 May 2022 01:13
Thanks @daveo that's always a last resort !
- wheelie100
25 May 2022 01:14
@hardrockminer I'm in Bella Coola, 5 hours west of Williams Lake...at the end of the road.
