Oil Filter Blowout
  • CobraTwo
  • CobraTwo's Avatar Topic Author
Oil Filter Blowout
16 May 2022 08:45
#867153
I changed the oil and filter in my 1978 KZ650.  I also changed the O-ring on the filter cover.  Took the bike to work (about 4 miles) and was on my way home (about 1/2 mile from home) when the filter cover popped out a little bit.  Needless to say, it was pushing the oil out.  I made it home and found oil pouring from the filter cover.  I tried tightening the cover bolt, only to have it pop out.  Ordered a new bolt, and this one seems worse.  Any ideas on a repair?  I greatly appreciate it.
  • martin_csr
  • martin_csr's Avatar
Re: Oil Filter Blowout
16 May 2022 08:50 - 17 May 2022 07:37
#867155
Stripped threads?  I'd say you'll have to drop the oil pan to get a look at the oil pump.
edit: ps: after doing the repair, be sure to use a torque wrench. If you do a helicoil type repair, you may have to modify the torque setting. ???  If the oil filter bolt threads are damaged, you may need to replace it.
Last edit: 17 May 2022 07:37 by martin_csr.
The following user(s) said Thank You: CobraTwo
  • zed1015
  • zed1015's Avatar
16 May 2022 09:26 - 16 May 2022 09:28
#867156
Sounds like you have possibly stripped the threads in the crankcase.
Helicoil type repair would be the way to go without pulling the engine apart.
Last edit: 16 May 2022 09:28 by zed1015.
