I'd like to teach the world to........
Re: I'd like to teach the world to........
14 May 2022 13:13
- davido
14 May 2022 15:18
Thanks Mikaw. Very interesting.He does mention paint stripper,so I might be on to something there.I'll hopefully have some results in the morning. Though I've noticed that the paint stripper of today is nowhere near as strong as it used to be. We will see.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
15 May 2022 04:45
I've always vapour blasted (aqua blast) with no concerns. Just re-seat the valves when you put the head back together.
- davido
15 May 2022 11:10
Not up for blasting. Budget and time wont allow it plus I'm leaving the valve guides in place. I'm just looking for a safe and effective way to DIY. I had everything in paint stripper overnight. Very underwhelming result. I think its doing something but hard to tell. I'll give it another night and see how it goes.
I bought a couple of these;
www.dremel.com/au/en/p/high-performance-...brush-26-mm-538-v175
Any thoughts on whether they'll be safe enough to use on the valve seats? I want the seats clean as possible before lapping.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- DOHC
- Those Doe-Hawks really go!
15 May 2022 11:20The application list includes aluminum, but also gold and silver. Those are pretty soft, so this brush might really be more for polishing that removing gunk.davido post=867129https://www.dremel.com/au/en/p/high-performance-abrasive-brush-26-mm-538-v175
I have used both the Dremel brass and stainless steel wheels to clean aluminum. They work well.
www.amazon.com/gp/product/B015PK5DRY
www.amazon.com/dp/B015PK3CIQ/
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
15 May 2022 11:23
Only use a brass brush, nylon is to soft on carbon.
- zed1015
15 May 2022 11:28 - 15 May 2022 14:00
If you haven't access to a blaster then a brass wire wheel in the drill works well in the combustion chamber and It won't harm the hardened valve seats .
For scraping carbon off piston crowns etc then copper plumbing pipe with a flattened and sharpened end is the welll known tool.
Valves will clean up with a wire wheel or a decent scraper.
You won't damage the valves as they are hardened steel
Last edit: 15 May 2022 14:00 by zed1015.
- willemZ900
- Z1B 4 ever
15 May 2022 12:41
Davido, ovenreiniger en anders wetblast Almere.
