81 KZ305 using alot of oil
- ckahleer
04 May 2022 08:25
It uses a quart every 250 miles. Does not smoke at idle. Don't see smoke in mirrors when riding. Doesn't leak.
Before I take the top end apart, is there something besides valves/seals and pistons/rings that would cause oil consumption?
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Nerdy
Re: 81 KZ305 using alot of oil
04 May 2022 10:15
It can burn oil without generating a lot of visible smoke, especially while you're riding. How do the plugs look?
Given the age of the bike, my first inclination is the valve guide seals have failed. The rings are less likely to be an issue unless there are a lot of miles on the bike.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- ckahleer
05 May 2022 07:53
The bike had 6,000 miles on it when I got it 2 years ago. It now has 8,000. It has used oil at this rate since I owned it. The plug electroids and insulator are tan. The metal base is black.
Can the valve seals be replaced without femoving the head?
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- ghostdive
05 May 2022 11:10
They cannot, but the 305 engine is very easy to take apart and reassemble.
2001 ZX-6R
2001 ZX-6R
- Ojisan rider
05 May 2022 20:17
Leaking from somewhere you can't see?
Not motorcycle, but I was chasing a oil leak on my 86' Monte Carlo SS with stock 305. For the life of me, I couldn't find the oil leak but I knew it was leaking as it does not burn the oil (checked both the exhaust and plug). No oil trace on the ground. Found the cause was oil leaking from back of the intake manifold and oil was dripping on the hot exhaust. I smelled the burnt oil but I always thought it was from car next to me as when I parked my car, I couldn't smell it.
Just my experience.
Just my experience.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
- z1kzonly
06 May 2022 07:49
