Kz1000 K2 shorter clutch cable
  • OkieZ1000
  • OkieZ1000's Avatar Topic Author
30 Apr 2022 19:28
#866447
Greetings,
I'm looking for some information on possible alternative clutch cables that would fit my 82  K2.
I've got flatter bars than stock and would like to shorten up the clutch cable so it's not sticking up above the guages.
The stock one appears to be 58.5 inches end to end and I'm looking for something in the 55 inch range.
Anyone have any info on swapped cables that might work?
Any info is appreciated
Thanks
Scott
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Kz1000 K2 shorter clutch cable
01 May 2022 00:07
#866450
Euro bikes have lower bars with shorter cables.
www.z-power.co.uk/search/products?keywords=Clutch+cable
The following user(s) said Thank You: OkieZ1000
  • TexasKZ
  • TexasKZ's Avatar
01 May 2022 05:26 - 01 May 2022 05:31
#866457
I wonder if a cable from a 1000J or 1000P would be short enough?
I suppose you could call a supplier and ask. Motion Pro also makes custom length cables.
www.motionpro.com/c/cables/
Last edit: 01 May 2022 05:31 by TexasKZ.
  • DFIGPZ
  • DFIGPZ's Avatar
06 May 2022 15:48
#866701
54011-070 is part # for Z1R clutch cable which is shorter.
1984 750 Turbo
The following user(s) said Thank You: Nessism, 750 R1, OkieZ1000
  • OkieZ1000
12 May 2022 11:46
#866972
Update for anyone else looking.
I found this part from Dennis Kirk (here in the US).
It fit perfectly for what I needed and was not expensive. (It's ~3.5 inches shorter with the same cable travel as stock).
www.denniskirk.com/parts-unlimited/clutc...pc8024.prd/C8024.sku
