Valve adjustment
  • Provie97
  • Provie97's Avatar Topic Author
Valve adjustment
15 Apr 2022 17:49
#865537
Hello to all and happy Easter. I’ve got a 1980 750 h1 and it wasn’t firing on the #2 and #4 cylinders checked all electrical and nothing was amiss. Would crank and start fine on 2 cylinders. I decided I would check the valve clearances and they where off on both none firing cylinders with no clearance at all so I changed them out. Now, the Nike struggles to try and start but doesn’t quite make it. What could I have done wrong. Almost like it’s got too much compression?  Thanks in advance for any input.
  • TexasKZ
  • TexasKZ's Avatar
Re: Valve adjustment
15 Apr 2022 19:51
#865541
Double check the plug wires. It is easy to connect them to the wrong cylinders.
The following user(s) said Thank You: Provie97
  • Provie97
15 Apr 2022 21:41
#865544
No. That’s not it. I’ve changed the coils multiple times and even went back to points ignition instead of electronic to cut down on the electrical aspect. Could I have the cam chain too tigh,  I know by going from running on two cylinders then going to all four theres going to be more compression, but enough to strain a fully charged battery and still not fully fire off. Idk. I’m stuck lol
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
16 Apr 2022 00:33
#865547
The more cylinders that are firing the easier it is on the battery. There is no more compression ( unless previously the valves weren't closing) but the firing cylinders help to spin the motor. What exactly have you done when setting the valve clearances ? What is the battery voltage when cranking ?
  • zed1015
  • zed1015's Avatar
16 Apr 2022 02:43
#865551
Did you remove the cam chain tensioner before re-fitting the cam cover.
If you didn't the HYVO camchain will be too tight  and you should remove the tensioner, back it off and re-fit asap before any other attempt at starting.
The following user(s) said Thank You: Nessism, Provie97
  • Provie97
16 Apr 2022 19:49
#865593
I kinda retraced my putting the intake cam back on after adjusting the # 6 and #8 valve shim and when putting the valve cover on there was tension on the cam chain before it was seated correctly.but Being new to this I still bolted it up and called it good. I went back in to see what I did wrong and i was one tooth off on the sprocket. I corrected that and started it up and oil started coming from around the exhaust manifold and maybe the spark plug area  I got aggravated with it and went fishing. But I’m about to check it out. Thanks for the patience
