Oil pressure switch
  • Elfarm98648
  • Elfarm98648's Avatar Topic Author
Oil pressure switch
30 Mar 2022 13:58
#864552
1981 KZ759(4) LTD
I got off the bike after not a particularly hard ride but probably an hour long, and I see my boot is covered in oil. Never good, all down that side of the bike has splatters of oil. I pull the ignition cover off and I believe it is my oil pressure switch.
as you can see it makes sense what is what is leaking but I haven’t pulled the ignition cover back off to check. My question is where can I find one of these? Z1 doesn’t show the correct part number, 16144-006. Is my only option eBay?
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Oil pressure switch
30 Mar 2022 14:37
#864556
  • Elfarm98648
30 Mar 2022 14:45
#864558
Thank you. Unfortunately they are located in the UK. With the world the way it is now I don’t know when it will arrive.
  • Elfarm98648
30 Mar 2022 14:53
#864559
Will that part number work?
Schematics show the original part number as 16144-006. However the part number of what he gave me was 27010-1313. They appear the same but when I look up the 1313 number it shows a 90s ninja as fitting.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
30 Mar 2022 16:19
#864564
It's hard to know if that other part number is correct.  Even if it fits, it may be set to a trigger at a different pressure.
How about this one:  ebay.com/itm/144450342220
My dad's '74 Z1
'00 ZRX1100
  • Elfarm98648
30 Mar 2022 17:37
#864570
Thank you sir!! Do you know if it has a torque spec or needs Teflon tape? Just trying to get my ducks in a row before I pull the old one.
  • Elfarm98648
30 Mar 2022 18:58
#864579
Well I was able to limp it home, topped it to the top of the sight glass and it took half a quart! Luckily I only live half a mile from work which is where the leak happened. Well on the half mile trip home, it lost all of the half quart and is now back down to the bottom of the glass. It was running maybe 3-5 minutes at most. One thing was odd, when I got on the bike and turned the key to ON, it showed I had oil pressure when the bike wasn’t running… definitely think it’s a bad sensor because the screw was connected and tight.
I pulled off the ignition cover and dyna plate and removed the old sensor. Nothing seems to be physically wrong with it but it did have oil down in the screw hole for the switch to connect to. Cleaned everything up and now waiting on the part to arrive. Should be here Friday or Saturday.
  • DOHC
  • DOHC's Avatar
30 Mar 2022 20:18 - 30 Mar 2022 20:23
#864594
You need to get a copy of the factory service manual.  All of the answers are in there.  There may be a PDF copy in the Filebase on this site.
Here is one that covers your bike: ebay.com/itm/132106687961
EDIT:  Found the PDF in the filebase:   kzrider.com/filebase/download/17-kz750/1...e1-h1-service-manual
My dad's '74 Z1
'00 ZRX1100
Last edit: 30 Mar 2022 20:23 by DOHC.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
30 Mar 2022 22:37 - 30 Mar 2022 22:39
#864597
You get eye cancer from this service manual, it´s a really bad copy. You better use the colored one from 750turbo.com.
www.750turbo.com/manuals/GPz750_Base%20Manual.pdf
Last edit: 30 Mar 2022 22:39 by Scirocco.
  • martin_csr
  • martin_csr's Avatar
31 Mar 2022 07:49 - 31 Mar 2022 12:56
#864612
By Elfarm98648:  Schematics show the original part number as 16144-006. However the part number of what he gave me was 27010-1313....
That 27010-1313 oil pressure switch was used on the ZR7/ZR7S (air cooled models based on the Z650/750 engine).
From the ZR-7S FSM:  standard oil pressure = 14.5 psi @ 3000 rpms.
There should be some info here on KZR about the ZR7 oil pump as it's kind of an upgrade for the 650/750-4s, so there might be something about the oil pressure switch.
Last edit: 31 Mar 2022 12:56 by martin_csr.
  • Elfarm98648
31 Mar 2022 17:16
#864642
Well, it sounds like that one may actually work for my application. I checked my FSM and it indicates 28-36PSI @4k RPM (194°). Well I’ll just wait for mine to get here.
  • Irish Yobbo
  • Irish Yobbo's Avatar
31 Mar 2022 18:13
#864648
It's unusual for these to fail and cause a leak, normally they would just wind out. But if it wasn't working either, then I suppose it needs replacing.
I saw plumbers tape mentioned. You can use plumbers tape if its all you have (it's the old-school home mechanic way of doing it), but really a medium strength thread locker is a better idea. Less sensitive to how much you put on, and if something does go wrong you won't have strips of PTFE sucked into tight oil passages.
1981 KZ750 LTD
