1980 kz 1000 mach 2 transmission
  • bikedog
  • bikedog's Avatar Topic Author
21 Mar 2022 12:53
#864131
Is there any diffrence between the clutch & transmission in a mach 2 engine and a standard kz 1000 engine
thanks,Steve
76 Z1
PSP 1075 stage 2 head
34mm mikunis
suzuki bandit 1250 swingarm
2012 hayabusa frontend and wheels
  • zed1015
  • zed1015's Avatar
Re: 1980 kz 1000 mach 2 transmission
21 Mar 2022 13:53
#864138
The Z1000 Mark 2 ( not Mach 2 ) gearbox and clutch has the same ratios and is a straight swap for the earlier 900/1000 items.
The Mark 2 does have slightly stronger / beefier gears and are considered the strongest of the kickstart ( pre 'J' style ) engined gearboxs.
  • bikedog
22 Mar 2022 04:47
#864167
thankyou appreciate it
yeah mark not mach
kawasaki did not make a speedracer edition
76 Z1
34mm mikunis
  • hardrockminer
  • hardrockminer's Avatar
22 Mar 2022 15:45
#864192
Kawasaki did make another transmission for the 903/1015 bikes.  I have one but am not currently using it.  You need to pull the kick starter to use it.
  • TexasKZ
  • TexasKZ's Avatar
22 Mar 2022 20:00
#864201
yeah mark not mach
Kawasaki did make a Mach II
www.classicsportbikesforsale.com/little-...saki-350-s2-mach-ii/
