Oil pressure gusge
- Missile2511
Oil pressure gusge
14 Mar 2022 16:37 - 14 Mar 2022 16:45
Hello all,
I have a project kz650b3 that has not run in some time. I am concerned that all I have to show oil pressure on first start up is the idiot light. Is there another way to verify oil pressure on first start?
Thanks,
Joe
Thanks,
Joe
Last edit: 14 Mar 2022 16:45 by Missile2511.
- Irish Yobbo
Re: Oil pressure gusge
14 Mar 2022 18:00
The 'idiot light' should really be sufficient. Oil pressure will typically be at its lowest at idle once warmed up. The oil pressure increases with revs, so the first sign that your oil pressure is going bad is that you will see the light start to turn on at idle once warmed up. If the light is off at idle, the oil pressure is almost certainly fine at higher rpms.
There is of course the case when the oil pressure sender is faulty. When this happens they're usually always-on or always-off which is pretty easy to diagnose. I you want to be sure, you can get another switch.
If you want to be really certain or want to know your exact pressure, you can unwind the oil sender, and wind in a gauge sender and plug in a gauge for testing. Check the thread as you may need an adapter, some of them are big (20mm or so), but I think the 650 and 750 engines have a more normal metric thread for the sender unit.
1981 KZ750 LTD
15 Mar 2022 16:46
Agree with Irish. The oil pump is foolproof, so don't worry about it. Adding a gauge, with related plumbing, will add more possible leak locations, thus defeating its purpose.
