General motor information for newbies
- NotTodayBuddy
14 Mar 2022 11:33 - 14 Mar 2022 11:44
Hello everyone! I’m new to bikes completely though I am mechanically inclined. I bought my first bike being a 1982 KZ 750. The guy who sold it to me said it was a Twin. Now I’m noticing as I learn that it is not. The vin is hard to read but I am in the process of trying to figure it out. On this bike the motor reads 750B. Which I presume is 4 cylinder. But this head only has 2 spark plugs and 2 exhaust ports. Please school me!
Last edit: 14 Mar 2022 11:44 by Street Fighter LTD.
Re: General motor information for newbies
14 Mar 2022 11:47
Welcome to KZRider
2 plugs , 2 carbs , 2 exhausts equals a twin cylinder bike
I fixed your pictures for you to be full size
Next time complete the install by clicking the install all tab
The following user(s) said Thank You: NotTodayBuddy
14 Mar 2022 14:21 - 16 Mar 2022 06:24
The pictures are a Twin as is the engine number. It's possibly an 80 G1 Ltd. see replies below >> KZ750-M1 CSR.
www.cyclechaos.com/wiki/Kawasaki_KZ750G
www.cyclechaos.com/wiki/Kawasaki#KZ
Here's a 4-cylinder. It's a KZ650-CSR but the 750H Ltd is virtually identical in appearance.
The exhaust pipes on every other KZ In-line 4 are going to look pretty much the same
Last edit: 16 Mar 2022 06:24 by martin_csr.
- Kidkawie
- I bleed premix
14 Mar 2022 18:16
Buy/download a factory service manual.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Irish Yobbo
14 Mar 2022 22:05
It's likely a
1981 KZ750 M
- right year, twin-cylinder, spoked wheels.
It may have had it's engine swapped at some stage. The engine has KZ750B1 stamped, which would sensibly match a 1976 KZ750 B1 . But I'm not an expert on engine numbers/codes and how they work.
Whatever the case - you have a KZ750 twin, not a four. Kawasaki were quite annoying in that regard - they had a KZ750 inline 4 (KZ750H, KZ750E, KZ750F) and also had a Kz750 twin (KZ750B, KZ750G, KZ750M). It's very confusing - even some of the CycleChaos links are wrong listing i4s as twins and vice-versa.
Whenever you are buying parts, check that the letter matches for a twin - most KZ750E parts will not fit on a KZ750B for example.
When I got my KZ750H2 (inline 4) I think the previous owner got a rear sprocket for a twin, because they put a 38 tooth sprocket (stock on a twin) on the rear instead of the correct 32 tooth (stock on a inline 4). The gearing was all messed up, but gee it was fast off the line.
1981 KZ750 LTD
The following user(s) said Thank You: martin_csr
15 Mar 2022 06:25 - 15 Mar 2022 06:40
I think you're right about it being a KZ750-M1 CSR. It's hard to see but it appears to be stamped KZ750BExxxxxx. All 750 Twins appear to use the same engine numbering. The engine is probably original to the motorcycle. I forgot about the 750-CSR, doh.
Last edit: 15 Mar 2022 06:40 by martin_csr.
15 Mar 2022 06:41 - 15 Mar 2022 07:00
There was also the 750K, twin cylinder, belt drive, LTD. As Martin said, so far as I have been able to discover, all of the 750 twin models used the same engine, so they are all stamped with 750BE.
You can download e document I linked to below, and look for your frame number to verify the model.
www.kzrider.com/filebase/download/64-gen...78-kz-by-the-numbers
Last edit: 15 Mar 2022 07:00 by TexasKZ.
15 Mar 2022 06:58
The only way to know for certain which model you have is by looking at the frame number (vin) stamped on the head stock. There should also be a decal beside the stamped number with the frame number, date and country of manufacture clearly printed on it. Since your bike has been repainted, that decal may not be visible.
- gd4now
- Denco where did you go?
15 Mar 2022 11:00
You might find the link helpful
kz750twins.com/?cat=23
You can find manuals to download, info on frame and engine numbers, ect.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
