79 Kz1000 swingarm removal
  • Deuce
  • Deuce's Avatar Topic Author
06 Mar 2022 09:27
#863249
Best way to remove these?  Both spin when turned.
www.flickr.com/gp/162005819@N03/J055kUZ1a8
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
Re: 79 Kz1000 swingarm removal
06 Mar 2022 09:42
#863251
On the ST there isnt a regular Pinion that runs from one side to the other but 2 lugs that support the swing arm like the pic below, once the bolts are gone off then pry nice and easy with a large flat head screwdriver or pry bar.
  • Deuce
06 Mar 2022 10:23
#863254
That easy?  Wow!  Thanks a bunch!
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Deuce
06 Mar 2022 11:40 - 06 Mar 2022 12:58
#863258
I should have also asked how the drive shaft comes out of the swingarm.  Mine pulls a little, then starts binding.
Never mind.  I finally got my fat head in a position that I could look into the swingarm, and I see the C clip.  Of course, I'm going to have to go buy a special pair of pliers just for that, since mine don't have a long enough reach.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
Last edit: 06 Mar 2022 12:58 by Deuce.
  • Deuce
12 Mar 2022 05:48 - 12 Mar 2022 05:50
#863621
Okay, I'm not as dumb as I'm making myself sound, lol.  One more question.  Does #5 have to come off before the swingarm will pull away from the shaft?  In this illustration, it doesn't look like it should have to, but if I pull the swing arm, it moves about 2 inches, then binds up.  That particular snap ring is really hard to get to.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
Last edit: 12 Mar 2022 05:50 by Deuce.
  • TexasKZ
  • TexasKZ's Avatar
16 Mar 2022 07:07
#863863
I think it would be easier to remove the pin (#6) and then remove the shaft with the swing arm.
  • Deuce
16 Mar 2022 07:12
#863864
I didn't know about the pin until I was doing some more research and found a thread here that mentioned it.  I finally got it all apart and the engine out.  This frame was bent, so It's going to the recycle center.  Now the REAL fun begins...stripping the good bike for rebuilding!
Thanks for all the help!
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • TexasKZ
  • TexasKZ's Avatar
16 Mar 2022 07:18
#863865
Bent frames can be straightened.
  • Deuce
16 Mar 2022 08:13
#863868
Not worth my time right now.  The area I live in is devoid of people able to do stuff like that anyway.  It looks like the left down tube got hit pretty hard and it "banana-ed" the spine.  You can see it in the picture.   I'm happy that I got several good parts off of it, including a motor.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
16 Mar 2022 15:34
#863884
Wooo, this frame is really twisted in any possible direction.....
