Sheared Woodruff Key on crankshaft
  • Wheelhop
  • Wheelhop's Avatar Topic Author
22 Feb 2022 04:26
#862734
Just wanted your guys thoughts on how to remedy "minor" damage to end of crankshaft due to a sheared woodruff key.
Zed1015 (thanks Rob!) suggested I use some fine valve grinding compound and carefully lap the rotor to the taper.  I spoke to a owner of a local
motorcycle repair shop and he agreed with that procedure. I have already bought 2 new woodruff keys online.  I am attaching a few pics.
Jim
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • Wheelhop
Re: Sheared Woodruff Key on crankshaft
22 Feb 2022 04:34
#862735
Here is a pic of the other end of the rotor.  The Woodruff key came out fairly easily and is shown above in 2 pieces.
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • zed1015
  • zed1015's Avatar
22 Feb 2022 06:02
#862740
After seeing the pics i can say that the damage is minimal and some carefull lapping will sort that out.
Just lap the bare minimum to get a smooth surface but don't try to eliminate all annular grooves that may be present .
Over lapping will move the rotor inboard slightly which can cause the starter gear to bind and you will have to lightly face the dished rubber damper that sits behind to regain clearance.
Some fine emery or wet 'n' dry on a flat surface or mirror can be used to reduce the dampers thickness if needed.
The following user(s) said Thank You: Mikaw, Wheelhop
