ARD Magneto removal help
  • Wheelhop
  • Wheelhop's Avatar Topic Author
13 Feb 2022 11:29
#862253
I am removing the ARD magneto ignition from my 1976  KZ900 project and wondering if anyone can help me with final steps.
I am attaching some pics:
I have removed the spring clip and a washer off of the end of last pictured area and just wondering how to proceed with removing rest?
do I need some kind of "flywheel puller" ?
thanks in advance for your help
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: ARD Magneto removal help
13 Feb 2022 11:39 - 13 Feb 2022 11:40
#862255
Isn't that just what the end of the crankshaft looks like?  I think you're done removing things...  Here is a random picture from Ebay of a Z1 crank.
ebay.com/itm/363703775721
My dad's '74 Z1
'00 ZRX1100
Last edit: 13 Feb 2022 11:40 by DOHC.
  • Mikaw
  • Mikaw's Avatar
13 Feb 2022 12:05
#862258
The snap ring holds the bearing cage on the crank. Your as far as you go. From here you can put stock or Dyna S on.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 Feb 2022 12:10 - 13 Feb 2022 12:34
#862260
Nothing more to remove on the crank end! You need only the ignition engine case, cover, gasket and oil seal.
A ignition advancer unit, bolt and nut is also needed for the conversion.
z-fever.de/shop/en/?cat=c519_MOTORDECKEL...MOTORDECKEL-519.html
Last edit: 13 Feb 2022 12:34 by Scirocco.
  • Wheelhop
13 Feb 2022 12:14
#862261
Cool, thanks for your help guys!
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • z1kzonly
  • z1kzonly's Avatar
13 Feb 2022 12:15
#862262
Great, now that it’s off, you can pack up and ship to me!
  • Mikaw
  • Mikaw's Avatar
13 Feb 2022 12:51
#862264
Right! Cool old school stuff!
  • carksz1b
  • carksz1b's Avatar
29 Jan 2023 20:38
#879436
Hi is the ard for sale
  • Wheelhop
30 Jan 2023 11:50
#879477
Sold it rather quickly in classifieds here
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
The following user(s) said Thank You: carksz1b
