I am a Goose.....
  • larriken
  • larriken's Avatar Topic Author
I am a Goose.....
10 Feb 2022 22:59
#862113
Hi guys, I have dropped one of the rubber timing chain dampers into the engine when removing the head. I have dropped the oil pan but for the life of me I can't find it. I have a sneaky suspicion that it is in sitting on top of the crank under the cam chain cog. Anyone have any suggestions on how to get the bugger out? Thanks in advance for your help.
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
Re: I am a Goose.....
10 Feb 2022 23:05
#862114
Hi, we all go through the same accidents, I had a similar problem, went to an auto shop and bought one of those (cheap) long spring with a push button on top, once pressed three/ four prongs at the bottom extend and grab the offending item. They are thin enough to go down that gap. Quack Quack
The following user(s) said Thank You: ghostdive
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
11 Feb 2022 00:15
#862115
Four weeks ago same problem, don't move the cranc, solved with a strong lamp and a long pincet.
  • hardrockminer
  • hardrockminer's Avatar
11 Feb 2022 04:30
#862117
Those dampers have a steel base.  Just drop an extendible magnet down to pick it up.
  • larriken
11 Feb 2022 16:21
#862143
Seriously! Never knew that. Off to the shed now to sort it out.
The following user(s) said Thank You: KZmarcel
