question about shifting Z1B
  • willemZ900
  • willemZ900's Avatar Topic Author
  • Z1B 4 ever
05 Feb 2022 08:59 - 05 Feb 2022 09:01
#861824
After new Cam chain, ect and new gaskets  i put the engine together and today i put it in the frame. (exhaust tomorrow) I can shift from free to the first gear by turning the rear wheel by hand  but i can not go to the second gear by turning the rear wheel. I thought i read somewere on the forum that this is normal situation and you can only go from the first gear to the second gear on a running machine. I this correct?
Last edit: 05 Feb 2022 09:01 by willemZ900.
  • zed1015
  • zed1015's Avatar
Re: question about shifting Z1B
05 Feb 2022 09:53
#861828
The gearbox if equipped with a neutral finder which prevents going into 2nd and above until you are moving.
The mechanism consists of 3 small ball bearings which disenage via centrifugal force.
If you spin the rear wheel fast enough by hand you can usually get the other gears or you can start the engine and shift through the gears with the bike on the mainstand.
  • Mikaw
  • Mikaw's Avatar
05 Feb 2022 10:00
#861829
Here’s a question. Say he spins the rear wheel fast enough to get to the upper gears. Can you down shift without the trans spinning?
  • willemZ900
  • Z1B 4 ever
05 Feb 2022 10:17
#861830
So it is only possible by centrifugal force, tomorrow i get the exhaust on and try with a running engine.
Thanks so far
Willem
  • zed1015
  • zed1015's Avatar
05 Feb 2022 10:50
#861836
Here’s a question. Say he spins the rear wheel fast enough to get to the upper gears. Can you down shift without the trans spinning?y
YES!
  • willemZ900
  • Z1B 4 ever
06 Feb 2022 07:26
#861874
Today put the exhaust on, everything works OK and no problem with shifting up to fift gear and back
