engine identification ZN1100 or KZ1100
- richard-GPZ
04 Feb 2022 21:22
Can any one tell me if there were any Kz1100 LTD's in 1985 or was there just the ZN1100 LTD that year?
I am trying to get a cylinder head off a 1985 ZN1100 motor. Do not want to make a mistake with the 1985 KZ1100 version if they exist.
Please help I don't want to make a mistake.
1983 GPZ-1100 completely stock
1983 Gpz-1100 hot rod build in process
- daveo
The following user(s) said Thank You: richard-GPZ
Re: engine identification ZN1100 or KZ1100
05 Feb 2022 07:22 - 05 Feb 2022 07:31
The last KZ 1100LTD was in 1983.
www.kzrider.com/filebase/download/64-gen...78-kz-by-the-numbers
Evenso, the heads may be interchangeable. They certainly share quite a few parts.
Last edit: 05 Feb 2022 07:31 by TexasKZ.
05 Feb 2022 07:44 - 05 Feb 2022 07:48
I think this is what he’s after.
This is copy and paste from a performance article written by Larry Cavanaugh
“It’s worth noting that the 84 & 85 LTD 1100 also received the same basic cylinder head as the GPz11 got in 83.”
So if Tex is correct then Richard your on the hunt for a ZN1100. I have also seen them listed as 1100 LTD. The 700 and 1100 are very, very similar in appearance. I have noticed the 1100 has “Kawasaki” cast into the clutch cover and the 700 is naked.
Last edit: 05 Feb 2022 07:48 by Mikaw.
- richard-GPZ
05 Feb 2022 17:03
Thanks Guys that was very helpful.
Looks like it is the right motor for me to use it's cylinder head with my 83 GPZ.
