Kawasaki kz1000 valve Kit standard
  • MLMG
  • MLMG's Avatar Topic Author
  • See you in the wind.
03 Feb 2022 10:17
#861728
Hello everyone, do these valves part number 12005-005 and 12004-012 work for me on a 1977 kawasaki kz1000?
Thank you
1977 Kawasaki KZ1000 A1
  • Mikaw
  • Mikaw's Avatar
Re: Kawasaki kz1000 valve Kit standard
03 Feb 2022 10:34
#861730
  • MLMG
03 Feb 2022 11:27
#861732
Thanks for responding, could it be that from z1 to kz1000 the valves are the same and only the name changes in the manual?
thanks
  • Dr. Gamma
  • Dr. Gamma's Avatar
03 Feb 2022 11:42
#861733
Keeper grooves are different from Z1 to Kz1000 valves. Dimensions of both valves are the same, just the keeper grooves are different.
You have to use Z1 valves with Z1 valve keepers and Kz1000 valves with Kz1000 valve keepers.  THE KEEPERS ARE NOT INTERCHANGEABLE!!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: MLMG
  • Mikaw
  • Mikaw's Avatar
03 Feb 2022 11:46
#861734
I’m assuming it in the spring keepers. AFAIK the valve sizes are the same. I don’t find your valve numbers on any 900/1000
Z1-Kz900 =12004-012 INT 12005-005 EX
77-78 Kz1000 = 12004-1010 INT 12005-1009 EX
  • MLMG
03 Feb 2022 12:44 - 03 Feb 2022 12:48
#861742
Well I'll see what I buy, thanks
Last edit: 03 Feb 2022 12:48 by MLMG.
  • zed1015
  • zed1015's Avatar
03 Feb 2022 15:24
#861748
Apart from the injection models all kickstart equipped Z1 through to MK2 use the same size valves.
However the early stock valves had square valve keeper (collet) grooves and ran in bronze guides and the later had round grooves and cast iron guides.
Due to the different materials used you cannot run an early stock square grooved valve in a cast iron guide so make sure the valves you buy have a rounded groove as these are compatible with the cast iron guides of your 1977 engine.
The following user(s) said Thank You: sf4t7, Mikaw, MLMG
  • MLMG
04 Feb 2022 09:10
#861781
Thank you very much for the information, I also plan to replace the guides.
