Valves squeaking ?
  • Provie97
  • Provie97's Avatar Topic Author
Valves squeaking ?
25 Jan 2022 16:51
#861095
Hey fellas. Hope everyone is well. I’ve got a question about the valves on my 1980 kz750 inline 4. When turning the engine over by hand while trying to make sure the advancer is working properly, I’m noticing a squeaking sound coming from where the valves would be. I got the bike non running and judging from how I received the bike they have never been adjusted. The odometer says it has 20,210 miles on it. This will be a first for me with calve adjustment so any advice is greatly appreciated. Thanks in advance
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Valves squeaking ?
25 Jan 2022 19:26 - 25 Jan 2022 20:14
#861106
Try loosening the spark plugs, or remove them.  This will relieve internal engine compression and allow the motor to rotate easier.
If you do remove them, make sure to cover each spark plug hole with a rag or something to prevent debris from getting into the engine cylinders.  I take time to cover the opening around the cam chain with a rag between adjustment rotations as well.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 25 Jan 2022 20:14 by daveo.
  • H1Vindicator
  • H1Vindicator's Avatar
26 Jan 2022 05:21
#861117
maybe everything is just dried out.
  • zed1015
  • zed1015's Avatar
26 Jan 2022 06:52
#861122
Cylinders full of mice
  • 750 R1
  • 750 R1's Avatar
26 Jan 2022 15:27
#861143
You never know !
  • Provie97
29 Jan 2022 08:03
#861355
I like the mice reply. I needed a giggle. But that makes since about it being dry. One of the carbs was leaking fuel into the engine a lot before I notice it and had to change filter and oil then let it air out for a while. I read on here that once you put the new filter and oil in you lay it down from side to side. Would that be right?
  • zed1015
  • zed1015's Avatar
29 Jan 2022 10:31 - 29 Jan 2022 10:35
#861378
No! Just spin the engine a few times on the starter with the plugs out ( to help spin the motor faster and give the battery an easier time) to get the filter full and the oil circulated.
Last edit: 29 Jan 2022 10:35 by zed1015.
