GPZ550 Heads and Cams Question
- 577nitro
17 Jan 2022 15:20
Good folks,
I have searched the forums but could not find a definitive answer to the differences in the GPZ550 heads and cams for the different years. I'm trying to
determine the cams profiles and head valve sizes for each of the years from 81 > 86. What I found on the net was suspect.
I know there was a list somebody put together a while back, but the links are dead now. Also there was GPZ550.com site, its dead too.
I know Corey knows a bunch, and some other smart folks too.
Thanks
Jason-
Thanks
Jason-
- 577nitro
Re: GPZ550 Heads and Cams Question
17 Jan 2022 15:24
I literarily just found this....doh!
gpzweb.s3-website-us-east-1.amazonaws.co...KZZXZR550500400.html
- 577nitro
17 Jan 2022 16:08
So follow up on my on post...has anybody applied the full tilt mods to the 550 engine with real dyno results? I am curious to see what a .410 lift, 12:1 Compression, 615cc kit will produce in HP/Torque.
anybody???
I think stock on a 85 was 65hp but is that the crank or RW?
JES-
anybody???
JES-
17 Jan 2022 16:17No way it was rear wheel.So follow up on my on post...has anybody applied the full tilt mods to the 550 engine with real dyno results? I am curious to see what a .410 lift, 12:1 Compression, 615cc kit will produce in HP/Torque.
anybody???
JES-
- Daftrusty
17 Jan 2022 18:34
I think this is as close to an answer to your question as one might get…..
www.kzrider.com/forum/2-engine/442737-gp...arbs-615cc-dyno-tune
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
- Injected
18 Jan 2022 07:21
That Wiseco piston kit has always been 10.25:1 - Where is that 12:1 coming from??
1978 KZ650B2 modified project
- 577nitro
18 Jan 2022 16:13That Wiseco piston kit has always been 10.25:1 - Where is that 12:1 coming from?
Its not a Wiseco Kit, search on Dynoman, he has a GPZ550 615cc kit that is 12:1CR. They are built to order and machined. He also can setup a set
of CR26mm carbs for the GPZ550 as well. I think he has some nice stuff, I've ordered a few things for my GPZ1100 with no issues.
JES-
- 577nitro
30 Jan 2022 11:05
Got my 84 cams in, defiantly can see the difference between the duration difference from the 81 cams. Hopefully it will pep it up some.
