The mistery hole
- shamal
The mistery hole
30 Dec 2021 11:50
Can someone please explain what the hell is this hole near the exhaust port in the head of the gpz/ zx750? And why is directly "vented" in a hole in the cam cover?
1983 kz 550 h
Re: The mistery hole
30 Dec 2021 11:57
It’s emissions control item. Kawasakis clean air system. Reed valves in the cam cover allow air into the exhaust to help burn excess fuel to pass emissions.
- zed1015
30 Dec 2021 12:00 - 30 Dec 2021 12:06
It's an air bleed port for the US emissions system.
Basically a dodge by Kawasaki to pass US emissions laws by bleeding air from the intake through a one way reed valve sited in the cam cover and into the exhaust port via that hole.
This was done to reduce (dilute) the parts per million count of toxic particles in the gasses being expelled out of the silencer.
Last edit: 30 Dec 2021 12:06 by zed1015.
30 Dec 2021 12:22 - 30 Dec 2021 12:24It's an air bleed port for the US emissions system.
Um, not exactly. When the exhaust leaves the combustion chamber it's still extremely hot, and injecting fresh air into the exhaust stream encourages any remaining raw fuel to burn while in the exhaust pipes. Tons of cars in the late 60's and through the 70's had air pumps for the exact same reason. Kawasaki's solution was very ingenious because it consumed zero power, unlike an air pump. One downside, especially for guys running headers, is increased exhaust temperatures. A small price to pay though.
Last edit: 30 Dec 2021 12:24 by Nessism.
- shamal
30 Dec 2021 12:38
Ok thank you for the response but i still dont understand, since my kz750 has the cam cover without the reed caps on it... So, is this system just completely useless on my model? Should i check something in the cover? I had an air pulse coming out front the left first one when engine was idling
1983 kz 550 h
30 Dec 2021 12:44This photo shows the air injection port being tapped so it can be plugged with a grub screw. Does your head have these ports? If so, you should plug them. I did that, and ran a Turbo valve cover, which doesn't have the air injection junk on it.Ok thank you for the response but i still dont understand, since my kz750 has the cam cover without the reed caps on it... So, is this system just completely useless on my model? Should i check something in the cover? I had an air pulse coming out front the left first one when engine was idling
- shamal
30 Dec 2021 12:54
Yes i have the ports as you show. I think once the cover is on , the cover itself can be a "plug" , or i am wrong? What can cause leaving the ports unplugged like you did?
1983 kz 550 h
- zed1015
30 Dec 2021 12:59 - 30 Dec 2021 13:14Yes! the system is dormant without the reed valve cover.my kz750 has the cam cover without the reed caps on it... So, is this system just completely useless on my model? I had an air pulse coming out front the left first one when engine was idling
The head is still drilled to the exhaust ports and you will feel a back pulse from the exhaust with the cover removed
You don't need to tap and plug the holes if you already have the correct cover.
Once the cover is installed it should have blanking lugs which block off the drillings
Last edit: 30 Dec 2021 13:14 by zed1015.
30 Dec 2021 13:43
The following user(s) said Thank You: shamal, BCScott, Dragbike_Mike
31 Dec 2021 07:14
Personally, I would install the grub screws anyway. The extreme pressure changes can cause the cam cover gasket to leak, allowing oil to be drawn into the exhaust port from the camshaft area.
- blipco
- 2002 KZ1000P
03 Jan 2022 12:00
I don't know what size the holes are but these fit the ZRX engine. Kwick lists the size.
www.kwick.biz/product/noflo-emission-pair-block-off-plug-set/
03 Jan 2022 19:57
I don’t think those will work on the KZ engines as there is no shoulder for the plug to bottom on. They work a treat on the ZRX, though.
