Camshafts B1 vs A1/3
  • Bozo
  • Bozo's Avatar Topic Author
  • Ride it like u stole it
27 Dec 2021 20:28
#859698
I am using GPZ1100A1 to 3 model camshafts on my GPZ1100B1 Head. I have standard pistons, valves with APE springs. My Question is there any cam timing I have to do to use these camshafts. I just did an engine leak test and all four inlets are leaking and I want to make sure the cam timing is not the issue.
  • zed1015
  • zed1015's Avatar
Re: Camshafts B1 vs A1/3
28 Dec 2021 05:21
#859707
The GPZ1100A cams are 110 degree lobe centers as stock which is the same as all the others so that shouldn't be the issue.
The following user(s) said Thank You: Bozo
  • 577nitro
  • 577nitro's Avatar
03 Jan 2022 01:39
#859964
Try lapping the valve seats,  worked for me, no more leaks.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 Jan 2022 08:59
#859975
Regarding 83-85 GPz camshaft use in KZ engines, consider the following post from one highly respected and sorely missed KZR forum member:
kzrider.com/forum/2-engine/596933-can-i-...gine?start=24#661583
1982 KZ1100-A2/1170 sleeper 😀
