Broken Spark Plugs Remedy?
  • Dr. Frankenstein
  • Dr. Frankenstein's Avatar Topic Author
10 Dec 2021 16:16 - 10 Dec 2021 16:21
#858928
Well, it happened Again; I was hoping it wouldn't but it did. This bike has been outside for a looong time, and when I went to take out the spark plugs what I thought was a turning turned into a Crunch..!
Yes, BOTH spark plugs turned all right; that little silver ring is what remains of the spark plug threads; on both sides! If you look closely you can see the remains of the spark plug tip in the cylinder.  It appears I have some work ahead of me.  Any ideas for getting those out?  I had soaked them in PB Blaster for a week and tried to use heat before I attempted to turn them, but they broke faster than Betty White's hip. It didn't take much.
Because of this I've back-burnered the KZ400 project until I can drop the engine and take it all apart, but I'm hoping somebody here has a solution...?
Last edit: 10 Dec 2021 16:21 by Dr. Frankenstein.
  • ghostdive
  • ghostdive's Avatar
Re: Broken Spark Plugs Remedy?
10 Dec 2021 17:00
#858929
I'd try a fluted screw extractor; I struggled with a broken plug like this in a variety of other ways and none of them went anywhere - least of all a spiral-type extractor. If that doesn't work, I'd pull the head, I think that's the path of least risk of damage.
2001 ZX-6R
  • Dr. Frankenstein
10 Dec 2021 19:19
#858933
Actually, I came upon this - a pipe nipple extractor from Lowes, $11 - Harbor Freight has one too, but this one seems a bit better:
Kobalt Pipe Nipple Extractor Set in the Plumbing Wrenches & Specialty Tools department at Lowes.com
I will of course report back when it happens.
  • F64
  • F64's Avatar
  • 81-KZ440D2
10 Dec 2021 22:14 - 10 Dec 2021 22:17
#858938
Check out Autozone's free loaner tool for a Ford Triton spark plug extractor.
It may work, but double check the clearances as the spark plug is a different size externally.
Ford trucks had a fun time breaking spark plugs so there was a tool created.
www.autozone.com/nuts-bolts-and-washers/...mover-set/409619_0_0
81-KZ440-D2.
LIC, NY
Last edit: 10 Dec 2021 22:17 by F64.
  • noman
  • noman's Avatar
11 Dec 2021 21:40 - 11 Dec 2021 21:46
#858971
of course i'd check the work done before install, but there's a refurbished replacement head (p/n 11002-1003) on ebay at the moment for $99/shipped.
i also have a spare head for a 79, in nice shape and less expensive.
79 kz400
66 S65
Last edit: 11 Dec 2021 21:46 by noman.
  • Mc Tavish
  • Mc Tavish's Avatar
11 Dec 2021 22:02
#858972
Ha, yeah. that was a PITA. Most F150's over here spat the plugs out all by themselves, no tool required!
1978 z650C
  • KZB2 650
  • KZB2 650's Avatar
12 Dec 2021 06:29
#858978
I've always used anti-sieze on mine and they've always came out like butter.
Some don't some do from what I've read on here but this is one thing I probably won't be talk out of.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: slmjim+Z1BEBE
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
12 Dec 2021 14:15
#858986
+1
We've used Bostik Never-Seeze Standard Grade on plug and other threads for decades.  Almost always on steel fasteners threading into aluminum.  Just have to be very careful not to over-torque, as can easily be done on lubed threads.
Good Ridin'
​​​​​​​slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
12 Dec 2021 19:02
#858989
Applying heat may help with the extraction. A magnet should get the tip out of the cylinder then suction out the porcelain.
  • Dr. Frankenstein
13 Dec 2021 09:45
#858998
Update - I tried the pipe nipple removers, but no luck there; after doing some more reading I've ordered some square fluted screw extractors to see if that makes a difference. What really bugs me though is I managed to break off two cooling fins with the breaker bar!
Noman, PM me about the head please; thanks!
  • z1kzonly
  • z1kzonly's Avatar
13 Dec 2021 13:13 - 13 Dec 2021 13:14
#859005
Drill out most of it!
EDM burn it out!
Research EDM ( electrical discharge machining)
Any and all of those e z out extractors are just going to push outward against the thread, binding it more.
Drill it out. put an insert back in!
I had a plug broke off in a 79-80 smog KZ1000 head. It sat for 20 years! it was not going anywhere! I drilled down to the minimum, the just chisled the thin metal out that was left. Got lucky to just run a nice sharp 14mm tap through. Not a plug chaser. It looks ugly, but with 3/4" of threads! A new plug will work fine.
At least I hope so when I sell the 12,000 mile head, all fresh and rebuilt on eBay!
This was one of my KZE1-E2 shafty's I bought to part out. Virgin low mile MarkII case and crank sold for $500 to the drag racers. I paid $200 for this whole bike!
The seller was the one who chisled up the opening. How do you spell (chisled??)
Last edit: 13 Dec 2021 13:14 by z1kzonly.
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
13 Dec 2021 15:08
#859018
Did you try heat?
