Timing adjustment
- Qsmothers3
Timing adjustment
25 Oct 2021 14:38 - 25 Oct 2021 14:39
Ok so I have gone through the manual and I didn't see anything in it about this ignition timing....I think its off because when the bike is running it stalls out around 4000 rpm and won't rev higher. How do I adjust the timing on this bike? I have racked my brain about this for days now and can't come up with an answer.....I've attached a photo...any words of wisdom would be appreciated.
Last edit: 25 Oct 2021 14:39 by Qsmothers3. Reason: Typos
- krazee1
Re: Timing adjustment
25 Oct 2021 14:47
Not made to be adjustable, you can cheat a little by elongating the holes on the plate the pickup is mounted on. Have you confirmed with a timing light that you have a timing problem? Are the mechanical advance weights free?
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- Qsmothers3
25 Oct 2021 14:52
So I dont need to set it at any particular mark and it will be fine? Also where do you test timing with a strobe? If you can't tell I'm very new to all this.....where are these weights located? I suppose the stalling could be a fuel/air problem i just figured it was a timing advance issue.
- gd4now
- Denco where did you go?
25 Oct 2021 15:28
I am sorry if you have in some other post indicated which model and year you have but I have not or do not recall reading it. If you had then that is on me not you. I do find it of help to see what bike(s) you have to help know which one you are talking about.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Qsmothers3
26 Oct 2021 08:51
My bad I forgot to say it is an 82 kz440. I cant get the darn thing to start at all now, it has gotten pretty cold here in missouri tho so may be thats the issue. Im just so lost at this point. As of last week it started and would idle with no problem every day, now it just cranks and on occasion will back fire really loud but never start.
26 Oct 2021 10:13
Looks like the spark advance may be frozen. Lube it and be sure the arms move freely and the springs work as they should.
- Qsmothers3
26 Oct 2021 11:16
If that's all you have. Better on penetrating oils on the market.
26 Oct 2021 18:35
Liquid Wrench and Kano Kroil are excellent penetrating oils.
