Neutral position switch for Z1
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
01 Oct 2021 08:41
#855999
Does anyone know if the Z1 takes the same neutral position switch as the KZ900 and KZ1000?
KZ900; Z1
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Neutral position switch for Z1
01 Oct 2021 09:02
#856001
Z1 sells one that works according to their info.
www.z1enterprises.com/neutral-switch-kz1...00-kz900-z1-f11.html
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Robb2018
  • krazee1
  • krazee1's Avatar
01 Oct 2021 09:59
#856004
I believe the KZ switch will work but they are different. The body of the switch is plastic on the Z1A I am currently working on.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • Robb2018
  • 76 KZ900 73 Z1 A
01 Oct 2021 10:07
#856006
Just bought the one from Z1Ent.  I saw that plastic one on Ebay.  They're asking 100 bucks for it... whores.
KZ900; Z1
  • hardrockminer
  • hardrockminer's Avatar
01 Oct 2021 12:40
#856017
Yes, although there are a couple of versions of it.  One uses a male/female connector.  Another uses a tiny JIS screw to hold the wire in place...similar to the oil pressure switch.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
02 Oct 2021 07:54
#856067
We're seeing that the original plastic ones are tending to crack from age & heat, just sitting in place without being disturbed.  The metal ones that supersede the plastic switches have a different connector (ring vs bullet) as mentioned by hardrockminer, but it's a simple crimp-ring mod that can't easily be seen.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
