High temp grease?
- katit
High temp grease?
13 Sep 2021 17:13
FSM recommends using on clutch pusher (inside basket)
When I took it apart is was looking like gray anti-seize.
What is this grease? Is regular bearing grease (M1 synthetic) going to work?
- katit
Re: High temp grease?
14 Sep 2021 06:41
Noone? I guess any grease will do? Mainly curious what kind of grease is that because it didn't wash out with oil..
- krazee1
14 Sep 2021 07:10
The grease I remember using originally was called Black Pearl? basically a moly grease. We used the same grease mixed with motor oil as assembly lube.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
The following user(s) said Thank You: DOHC, katit
