crankshaft zx550 (GPZ550)
- Fairing_d87
06 Aug 2021 13:02
friends i have trouble! bought an engine but it is defective. broken two teeth on the crankshaft. a question, tell me, the crankshaft from KZ 750 is suitable for the KZ550 engine (ZX550-GPZ550)
Re: crankshaft zx550 (GPZ550)
06 Aug 2021 15:17
Welcome to KZRider
Sorry for your bad luck
Im not a 650 guy / expert , but I think it will fit
Im sure others with first hand knowledge will chime in
The following user(s) said Thank You: Fairing_d87
06 Aug 2021 15:55
Nope.
GPZ 550 bore/stroke = 58 x 52,4 mm
GPZ 750 bore/stroke = 66 x 54 mm
KZ 650 bore/stroke = 52 x 54 mm
- Fairing_d87
06 Aug 2021 23:23
Thank you, the patient is just convinced. then another question will come from zephur (zr550) ???
07 Aug 2021 06:40
I am just wondering out loud (in electronic print) if the 750 crank and rods could be used with 550 block, pistons and head, for a 58 X 54mm combo?
07 Aug 2021 06:58
650's and 750 share a lot of engine parts, but not with the 550. The smaller engine is quite different.
07 Aug 2021 07:01Looks like the same part number for Zephyr and GPz.Thank you, the patient is just convinced. then another question will come from zephur (zr550) ???
www.partzilla.com/product/kawasaki/13031...ae66e4cfe67886ff8b95
- loudhvx
07 Aug 2021 10:50 - 07 Aug 2021 10:52
Cylinder spacing is closer on the 550 than 750/650. That should make for a challenging fitment project.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 07 Aug 2021 10:52 by loudhvx.
07 Aug 2021 18:49What’s a little rod curve between friends?Cylinder spacing is closer on the 550 than 750/650. That should make for a challenging fitment project.
- Fairing_d87
08 Aug 2021 20:35 - 08 Aug 2021 20:36
Thank you very much! I will search from him, it is easier to find him. after I write about the results (instagram #wiats)
Last edit: 08 Aug 2021 20:36 by Fairing_d87.
- F64
- 81-KZ440D2
08 Aug 2021 21:42
or you could just have the gear repaired
81-KZ440-D2.
LIC, NY
LIC, NY
- Fairing_d87
11 Aug 2021 03:57
I thought about it too. but where can I find such a good uncle in the video))) I'm considering this option if I don't find a crankshaft
