What's the purpose of...
- Claude.
30 Jul 2021 08:34 - 30 Jul 2021 08:36
... the cover installed over (or under) the oil filter?
In my 20+ years or maintaining my previous ZX-11, I always installed the said cover over the oil filter. I was surprised to see it goes under the oil filter on my KZ750L but that goes over on my KZ1000J (as on ZX11). Every other parts are about the same so I'm wondering why and what is the purpose of the shown cover.
Pictures comes from OEM parts manuals.
Thanks!
Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 30 Jul 2021 08:36 by Claude..
- loudhvx
Re: What's the purpose of...
30 Jul 2021 08:53
Ahh. What was the purpose of the
Nazca Lines
?. Who built the pyramids and how? Stonehenge?
Those questions pale in comparison to the Kawasaki filter cup mystery. And some bikes use the same setup with no cup at all.
Robert Stack never got to the bottom of it despite highlighting it in no less than 4 episodes of Unsolved Mysteries.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: rstnick, DOHC, DoctoRot, Robb2018
30 Jul 2021 09:47Yup, that pretty much sums it up.Ahh. What was the purpose of the Nazca Lines ?. Who built the pyramids and how? Stonehenge?
30 Jul 2021 12:05
I'm going to guess and say that the purpose is to drive oil through the filter before it moves into the lube system. Without the cup (on the 1000) oil could potentially flow through the filter and on to the lube system.
30 Jul 2021 12:25 - 31 Jul 2021 06:58
I don't know. I would have guessed the fence is supposed to deflect the oil entering thru a galley to keep the oil pressure from deforming the filter or something. The KZ650 oil pan has an orifice in the oil pan & the fence is fitted at the bottom of the oil filter. I've never looked at the 1000 setup.
Last edit: 31 Jul 2021 06:58 by martin_csr.
30 Jul 2021 12:34 - 30 Jul 2021 12:34
I´ve been ridden my Z1B for more than 25 years without the cover on top or bottom of the filter with no problems.
For me there there no technical advantage to use this oil filter bucket cover in the future, because KHI didn´t explain anything about it.
If you feel safer with the bucket(s), so put one on top and bottom, give it a try and report here......
Last edit: 30 Jul 2021 12:34 by Scirocco.
30 Jul 2021 12:37
Oops, I didn’t even know I was supposed to have one.
30 Jul 2021 12:43 - 31 Jul 2021 07:01
From EB pics the 1000 oil pan doesn't have an orifice, so the oil inlet must be via the crankcase, hence the fence at the top. My guess is that the barrier isn't needed in most cases but adds an extra level of protection for the filter. Some oil filters have a mesh screen around them & don't have the fence.
Last edit: 31 Jul 2021 07:01 by martin_csr.
- willemZ900
- Z1B 4 ever
30 Jul 2021 12:49Please Log in or Create an account to join the conversation.
30 Jul 2021 14:07
I dont recall my bike having one when new.
- Dr. Gamma
30 Jul 2021 15:13 - 30 Jul 2021 15:15
The '73 to '80 900/1000 kickstart motors NEVER used that oil filter cup.
Kawasaki started using them on the non-kickstart 1000J model motors in '81.
1986 RG500G 2 stroke terror.
Last edit: 30 Jul 2021 15:15 by Dr. Gamma.
- daveo
