kz-550 Decently Extreme Backfiring
  • Inspidship
  • Inspidship's Avatar Topic Author
  • 1980 KZ-550
29 Jul 2021 09:44
#852777
Hola folks. I threw this in the carb category mostly because I think it could be either engine or carb but ill roll with it for now.
To sum up the build so far, ive put pod filters on, cleaned up the engine, checked valve clearances, got proper 2 ohm coils (points ignition), got a 4 into 1 header with a little straight through glass pack (for now). Bike has some really really mean backfiring after letting off throttle. Foot and a half fireballs. Im assuming this isn't normal. Ill list my carb specs below just in case anyone has any recommendations regarding that. Any input is appreciated and I will be actively checking in and updating with any answers that may assist in finding the problem. Thanks a ton!
Pilot Jet - 37 (I think)
Main Jet - 97ish (#61 drill bit)
Needle - 3rd groove up
1980 KZ-550
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: kz-550 Decently Extreme Backfiring
29 Jul 2021 10:27
#852780
Just guessing but it sounds like a lean condition brought on by pods and a straight thru exhaust. What do the plugs look like?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Inspidship
  • ckahleer
  • ckahleer's Avatar
29 Jul 2021 13:01
#852789
Apply some choke or enricher when decelerating. Does it help or hurt?
Turn pilot screws to maximum richness.
Raise needles to highest clip position.
Increase pilot jet size.
You may have to richen your idle circuit more than you like to ge rid of the decel pop.
Of course, foot and one half fire balls are kind of cool too.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Nessism
  • Nessism's Avatar
29 Jul 2021 17:35
#852810
Messed up jetting brought on by the mods.  And points will burn with 2 ohm coils, although this is unlikely to cause fireballs out the exhaust.
  • bluej58
  • bluej58's Avatar
29 Jul 2021 18:17
#852814
Stupid question, have you checked to make sure all your header pipes are getting warm when you start it?
78 KZ1000 A2A
  • Inspidship
  • 1980 KZ-550
29 Jul 2021 18:39 - 29 Jul 2021 18:41
#852819
( In response to plug question) Plugs look decently black after pulling them
1980 KZ-550
Last edit: 29 Jul 2021 18:41 by Inspidship. Reason: Forgot to quote
  • Inspidship
  • 1980 KZ-550
29 Jul 2021 18:42
#852820
Foot and a half fireballs are super sick. The bike also seems to Peter out around 5k rpm on the main jet im guessing. Do you think richening that would have an effect?
1980 KZ-550
  • Inspidship
  • 1980 KZ-550
29 Jul 2021 18:43
#852822
I didn't use that method, but if the goal is to find out if all cylinders are firing, I had a problem with one not firing, so I pulled one spark plug at a time and checked for engine noise changes. If thats not the goal, ill throw a thermometer on it and try that out
1980 KZ-550
  • Inspidship
  • 1980 KZ-550
29 Jul 2021 18:44
#852823
I tried my best to follow jetting protocol from another forum post on here, my main jet is a little lean from what they call for though but I wasn't sure if that would affect it. Also I lied, I used to have 2 ohm coils and recently got 4 ohms because of the points
1980 KZ-550
  • ckahleer
  • ckahleer's Avatar
29 Jul 2021 19:48 - 29 Jul 2021 19:55
#852826
I once had a CL response to a bike I was selling, saying the bike looked sick. I was offended, but my son assured me it was a compliment.
With your mods, I would expect several trial and error carb adjustments. Yes, see if larger jets help or hurt.
I like figuring these things out with plug chops. 10 minuets at idle. 10 minuets at steady 60mph. A few minuets at the highest speed you dare.
To reduce popping, you may need to go a little rich at idle. dark brown is OK, but not sooty black.
1997 ZL600
94 KE100
82 KZ305
74 TC185
Last edit: 29 Jul 2021 19:55 by ckahleer.
  • bluej58
  • bluej58's Avatar
30 Jul 2021 04:16 - 30 Jul 2021 04:20
#852835
I'm not suggesting that you grab hold of a hot pipe but when you first start the bike up you can lightly hand tap each header pipe very quickly to see if they are all warming up.
If you have a infrared thermometer even better.
Be careful!
78 KZ1000 A2A
Last edit: 30 Jul 2021 04:20 by bluej58.
  • TexasKZ
  • TexasKZ's Avatar
30 Jul 2021 06:00
#852836
Be careful!
you can also spray a fine mist of water on each pipe and note how quickly it evaporates. Much less painful than touching the pipes.
