Mystery no-start situation - Help!
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Mystery no-start situation - Help!
27 Jul 2021 13:49
#852640
Not sure if this will be of any more help or not, but you might want to read the 60/40 test from the link below.
www.motorcycleproject.com/text/the_60-40_rule.html
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
27 Jul 2021 15:03
#852646
That it won't fire with ether is telling.
Is full battery voltage at the coils?  The internal contacts on old ignition switches can cause fairly severe voltage drop.
Maybe try attaching a timing light & cranking while observing the timing mark(s) on the advancer to make sure spark is happening when it's s'posed to.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • jekyllman
  • jekyllman's Avatar Topic Author
28 Jul 2021 21:45 - 28 Jul 2021 21:46
#852761
So I was able to get some life back into it. Just fitted the plugs and wires a little better. Still barely runs with JUST the right amount of choke and throttle. Definitely dies the minute I let off the throttle.
I took a video of the points while turning over the engine. Thoughts on the different seen between the two points contacts?
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
Last edit: 28 Jul 2021 21:46 by jekyllman.
  • jekyllman
29 Jul 2021 09:24
#852776
Better video:
imgur.com/a/JYsGV69
  • Rick H.
  • Rick H.'s Avatar
29 Jul 2021 10:04
#852779
I am no expert in this area, but that spark coming from the front(?) set of points isn't right.  In fact it's way bad.  That much spark coming off theose points will definitely damage them.  Have you done anything with the ignition circuit at all such as replace points and condensers?  The point sets appear to look different to me but I can't tell for sure.  I used to see a little bit of intermittent spark off the points, before installing the Dyna setup, but it was very small and hard to see.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Mikaw
  • Mikaw's Avatar
29 Jul 2021 11:18 - 29 Jul 2021 11:19
#852783
Condenser is bad, or the points face are flashed. You can try to resurface the points and reset gap, but I’m thinking the condenser is bad
Last edit: 29 Jul 2021 11:19 by Mikaw. Reason: Spelling
  • F64
  • F64's Avatar
  • 81-KZ440D2
29 Jul 2021 13:31 - 29 Jul 2021 13:52
#852791
It may not be an issue but in the video your points plate is out of adjustment range.
It's not centered in the slots.
You may have compensated for it with individual points adjustments.
You might double check you are firing on the  "F" mark not the "T" mark.
81-KZ440-D2.
LIC, NY
Last edit: 29 Jul 2021 13:52 by F64.
  • Rick H.
  • Rick H.'s Avatar
29 Jul 2021 13:35
#852792
That's kind of my thought too Matt, but looking at the points leads me to think they need to be replaced.  The right side looks really corroded but there's so much spark flash I can't get a good look at the left.  I don't think I have ever seen a set of points with this much spark flash.  Wouldn't want to get my fingers close to it.
Rick H.
Rick H.
  • F64
  • F64's Avatar
  • 81-KZ440D2
29 Jul 2021 13:43 - 30 Jul 2021 07:09
#852793
The condensor keeps that sparking down, but wondering if  those are Kawasaki condensors.
The OEMs are much better just not cheap. They're about $35 on ebay..not bad.
Get the oem points as well.
Funny, I'm reading a book that may have the same issue as you have.
81-KZ440-D2.
LIC, NY
Last edit: 30 Jul 2021 07:09 by F64.
The following user(s) said Thank You: Robb2018
  • jekyllman
10 Aug 2021 11:28
#853516
New condensers and we're golden!! Finally! Thanks everyone for you help on this. I probably wouldn't have figured this one out.
  • Robb2018
  • Robb2018's Avatar
  • 76 KZ900 73 Z1 A
10 Aug 2021 15:21
#853533
So don't leave us hanging... what did the hotel manager want?
KZ900; Z1
The following user(s) said Thank You: tdogm6@yahoo.com
