Kz1000P shifter jams on upshift.
- Frankiestank
04 Jul 2021 15:36 - 04 Jul 2021 20:15
Hello,
January I purchased my first KZ and am slowly getting it roadworthy again. Shes a 1993 KZP. 12000 miles on the odo. I purchased from an old timer who bought it at auction in 2005 and quickly parked it in the back of his heated garage.
I promptly went to replace the 15yr old tires, chain, fork seals, carb boots, spark plugs and fluids... on the road again!
After my first ride I found three more issues to address before i can put it on the road. I had a burned out clutch, coutersprocket was pissing oil and finally, my shifter pedal jams.
So back into the shop and over the next few days I address these new issues.
for the shifting problem... I found that all springs in the mechanism are in good shape. It seemed like the "kick pawl spring #92083-018" was worn so that was replaced.
I buttoned up the bike hoping I had fixed all my issues and could finally put some miles on these new treads!
I was wrong and my shifter still sticks on the up (heel) shift. This bike has the rocker style heel-toe shifter. Has any member address this issue in the past?
No parts appear to be bent. Or broken. The pedal linkage appears to operate smoothly which makes me believe the issue is internal and behind the sprocket cover.
All help and guidance is appreciated. I am SO happy to join the KZ family. If any other KZP riders are here in Vancouver, BC. Let me know and let's go for a cruise!
Last edit: 04 Jul 2021 20:15 by Frankiestank.
Re: Kz1000P shifter jams on upshift.
05 Jul 2021 04:20
When you re-assemble the engine the shift change drum must be set in neutral or the tranmission won't shift when everything is back together. Do you know if the engine has ever been apart?
If not, then I am guessing the shift forks are somehow stuck.
- ThatGPzGuy
05 Jul 2021 04:47
Have you checked the linkage? The shifter linkage needs to be properly adjusted for the heel-toe shifter to work. There is a section in the manual on how to do it but you eyeball it if you need to.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Frankiestank
- Frankiestank
05 Jul 2021 07:06
Thank you for your answer.
this motor has never been opened up.
the shifting happens flawlessly. It's just that I must "tap with my toe" to re-center the shifter before I can upshift again. The gears change without hesitation. I like what "ThatGPzGuy" says about adjusting the linkage.
Maybe It twisted while off the bike and the linkage is too short. Will be a good place to start.
- Frankiestank
05 Jul 2021 07:08
I will try then after reassembly.
its possible that I accidently adjusted the length of the adjustment part. I'll try to Lengthen or shorten. Hadn't seen that chapter in the manual so I will review this evening.
I had no troubles shifting at first. Bot until I removed and reassembled the shifter that the issue occured.
- ThatGPzGuy
05 Jul 2021 12:40
Hopefully it is that simple.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- blipco
- 2002 KZ1000P
06 Jul 2021 11:34
I probably will be of no help but mine did not want to shift when cold with 15/50 oil. Once thoroughly warm it was fine.
Also, I hated the heal/toe shifter so I cut off the heal part then heated the front portion and bent it to make it a toe only shifter.
- Frankiestank
21 Jul 2021 11:40
Got it solved!
ThatGPzGuy
, thank you. it was simply an adjustment. when the shop mounted the pedal they installed it too far one way.
no more issues and my bike is back on the road after a 15 year hiatus.
- ThatGPzGuy
22 Jul 2021 07:48
Awesome! I'm glad it worked out. Nothing like a cheap and easy fix.
Enjoy the bike and watch out for the cop bike curse.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Frankiestank
22 Jul 2021 10:38
Tell me more of the curse... I have never heard of that!
This bike has no decals on it. however I still had a cop roll down a window to talk/look at it at a red light.
- Robb2018
- 76 KZ900 73 Z1 A
22 Jul 2021 14:00
Curses don't exist until you hear they exist. It's all a self fulfilling mind fk.
KZ900; Z1
22 Jul 2021 15:32
Many who ride ex-cop bikes report that cagers will suddenly hit their brakes when they see you in their rear view mirrors, mistaking you for an actual cop.
