550 auto cam chain tensioner cap
  • Hawghunter
  • Hawghunter's Avatar Topic Author
28 Jun 2021 13:54
#850849
The cap is stuck and I dont want to overdo the pressure to remove it. Been putting blaster on it and letting it sit all night.  No luck.
any suggestions.
1981 KZ550-A2
touring Red Rocks of Arizona on my KZ Red Rocket
  • krazee1
  • krazee1's Avatar
Re: 550 auto cam chain tensioner cap
28 Jun 2021 14:20
#850851
LIGHT tapping, a little heat, and maybe a little Prayer?
Good Luck!   Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • TexasKZ
  • TexasKZ's Avatar
30 Jun 2021 06:21
#850947
For heat, use an electric heat gun, or if you are desperate and she is not at home, a hair dryer.
Do not use anything with a flame that close to carburetors full of gasoline.
The following user(s) said Thank You: krazee1
  • Pagala
  • Pagala's Avatar
30 Jun 2021 08:57
#850958
You'll get it off.
Just beware when putting it back on.
Those things really don't like being overtightened - they shear along the threads. If that happens you'll need a replacement CCT body.
1̶9̶8̶3̶ ̶K̶a̶w̶a̶s̶a̶k̶i̶ ̶G̶T̶5̶5̶0̶ ̶(̶U̶K̶-̶o̶n̶l̶y̶ ̶m̶o̶d̶e̶l̶)̶,̶ ̶a̶l̶s̶o̶ ̶k̶n̶o̶w̶n̶ ̶a̶s̶ ̶t̶h̶e̶ ̶Z̶5̶5̶0̶ ̶G̶1̶,̶ ̶r̶e̶g̶i̶s̶t̶e̶r̶e̶d̶ ̶i̶n̶ ̶1̶9̶8̶4̶.̶
1981 Kawasaki Z440 (KZ440C1)
  • Hawghunter
30 Jun 2021 17:49
#850986
Thank you
no prayers needed. In anger or otherwise.  Used heat, by riding. Then tapping. Put end of wrench against it and tapped with rubber mallet. A socket by hand removed it.  I was surprised that there is no washer.
i reinstalled with very little tightening.
thank you.
1981 KZ550-A2
  • Nessism
  • Nessism's Avatar
30 Jun 2021 18:16
#850987
There is supposed to be a soft aluminum washer between the cap and the tensioner body.
  • Hawghunter
30 Jun 2021 18:30
#850988
Oh great.  I better get a closer look.
1981 KZ550-A2
  • TexasKZ
  • TexasKZ's Avatar
03 Jul 2021 17:00
#851212
Number 7 in the diagram. Looks like it is still available, though a bit pricy. I’d be tempted to check the nearest hardware store.
www.partzilla.com/catalog/kawasaki/motor...ensioner-80-81-a1-a2
The following user(s) said Thank You: Hawghunter
