Need to helicoil threads for head bolt #13 (#13 in tightening sequence)
- Gdailey2112
- 82 KZ1100D1
03 Jun 2021 03:35
Just not sure as to specific size of helicoil and drill bit needed for repair. Anyone know? Thanx
1982 KZ1100D1
Re: Need to helicoil threads for head bolt #13 (#13 in tightening sequence)
03 Jun 2021 12:33
03 Jun 2021 12:39
They are M6 x 45. Same has cam cover bolts, and cam cap bolts. I get the pitch later
03 Jun 2021 13:42They are M6 x 45. Same has cam cover bolts, and cam cap bolts. I get the pitch later
M6 pitch is 1,00 mm
www.gewinde-normen.de/en/iso-coarse-thread.html
- zed1015
03 Jun 2021 15:28
Kit you need is m6 x 1 mm.
Drill comes with kit 6.3mm or 1/4 inch
- Gdailey2112
- 82 KZ1100D1
04 Jun 2021 09:45Thank you!!! Confusion seems to trouble me when it comes to specific bolt sizes, thread pitches, etc. I'll grab an m6 x 1 mm. kit and gett'r done! Thanx!Kit you need is m6 x 1 mm.
1982 KZ1100D1
- z1kzonly
04 Jun 2021 12:46
Yes! Invest in a real kit! as the drill is a few decimals off standard, as is the thread of the tap! Great investment as you have a Kawasaki engine!
Even though, on those 2 end bolts!! I have been known to tap a US SAE 1/4" tap through before the heli-coil.
Your choice!
Good luck!
Your choice!
Good luck!
- Gdailey2112
- 82 KZ1100D1
02 Jul 2021 05:25
Thanks z1kzonly!! I'll try the US 1/4" tap trick and see if that'll work.
1982 KZ1100D1
