'82 kz1100 base gasket still leaks from left front corner
- Gdailey2112
- 82 KZ1100D1
26 May 2021 15:06
My base gasket replacement didn't solve my oil leak issue. Still leaks from left front corner, like it always has since PO owned it. I had recently replaced the four heavy O rings (oil galleys), base gasket, head gaskets, valve cover gasket, and four cam end caps. My highly regrettable mistake - due to budget no surface machine work was done. Even though I'd checked it all out with a straight edge. Not sure on which surface should be machined? Case or bottom of jugs? Or both? Much thanks in advance. Thanx! Gary
1982 KZ1100D1
Re: '82 kz1100 base gasket still leaks from left front corner
26 May 2021 15:23
Did you use OEM gaskets and seals, and make sure the surfaces were perfectly clean?
26 May 2021 16:00 - 26 May 2021 16:01My base gasket replacement didn't solve my oil leak issue. Still leaks from left front corner, like it always has since PO owned it. I had recently replaced the four heavy O rings (oil galleys), base gasket, head gaskets, valve cover gasket, and four cam end caps. My highly regrettable mistake - due to budget no surface machine work was done. Even though I'd checked it all out with a straight edge. Not sure on which surface should be machined? Case or bottom of jugs? Or both? Much thanks in advance. Thanx! Gary
Maybe time for an external oil feed mod?!?!
kzrider.com/forum/2-engine/608211-external-oil-feed-to-head
Last edit: 26 May 2021 16:01 by Scirocco.
- daveo
26 May 2021 17:04
Had the same thing happen once, but that was before I replaced the old stretched out stock cylinder studs with a heavy-duty set by APE. Several head changes since, and there are still no leaks with 42 ft. lbs. of torque on the head nuts.
1982 KZ1100-A2/1170 sleeper 😀
- Gdailey2112
- 82 KZ1100D1
26 May 2021 18:26Yes I used only OEM stuff from Z1. Yes, a rather tedious process but yes surfaces were clean. I hope not, but may have been a bit too aggressive on that corner while trying to remove stubborn gasket material, I dunno. Can underside of jugs be re-surfaced? ThanxDid you use OEM gaskets and seals, and make sure the surfaces were perfectly clean?
1982 KZ1100D1
27 May 2021 04:50I don't think Z1 sells OEM gaskets. Just checked the base gasket they sell for the 1100 and it's all of $6.99 and states "equivalent to OEM". NOT!Yes I used only OEM stuff from Z1. Yes, a rather tedious process but yes surfaces were clean. I hope not, but may have been a bit too aggressive on that corner while trying to remove stubborn gasket material, I dunno. Can underside of jugs be re-surfaced? ThanxDid you use OEM gaskets and seals, and make sure the surfaces were perfectly clean?
The following user(s) said Thank You: SWest, Mc Tavish
- Gdailey2112
- 82 KZ1100D1
27 May 2021 11:43
I believe the gaskets and seals were OEM, ...so please let me rephrase, they weren't the green athena (sp?) brand that I'd read to stay away from. I'll look for my invoice and give ya the part numbers to confirm. Thanx again. Gary
1982 KZ1100D1
- Gdailey2112
- 82 KZ1100D1
27 May 2021 12:07
Ok found the invoice, it was upper end kit Part # SU609-0847
1982 KZ1100D1
- Davereplicant
11 Jun 2021 06:42
I had this same issue a few years back. I traced it to a stripped thread on one of the crankcase studs - fixed with a timesert.
also check your studs aren’t bottoming out the head bolts fooling you into thinking the whole lot is tight, a set of the taller APE stud bolts fixed this for me too, leak free for 25k since.
- Gdailey2112
- 82 KZ1100D1
30 Jun 2021 09:59
Thank you! Yes, tracing down small oil leaks can really be challenging, often times it can seem so misleading.
1982 KZ1100D1
