Crappy exhaust remedy?
  • kawirider
  • kawirider's Avatar Topic Author
21 May 2021 19:23
#848842
Good evening all, I am nearing the end of fixing up an old project '78 kz650b2 but I am stuck with a nasty exhaust leak at the head. A few years back I purchased probably the cheapest exhaust option, the MAC 4-1, to just get the bike road-worthy again. A few years and some(?) wisdom later, I have revisited the exhaust by doubling up on gaskets and layering it all with copper rtv. (I even degreased and lightly wire-brushed the gaskets before the install). This still results in a leak at the head from improper flange seating on my #3 header. Has anyone had any success with the MAC 4-1 exhaust?
  • 750 R1
  • 750 R1's Avatar
Re: Crappy exhaust remedy?
22 May 2021 02:33
#848847
I just put a new Mac on my sons 650 I also used two sets of copper exhaust gaskets, left the originals in place and put new ones in front, no leaks, It did leak with just one set of gaskets, I also hate the tinny note it puts out so we are going with an alloy muffler I have spare, just have to sort out a new mid pipe...
  • martin_csr
  • martin_csr's Avatar
22 May 2021 07:10 - 22 May 2021 07:17
#848857
I don't know the best fix.  Have you checked the header tips w a straight edge?
What are the chances a muffler shop could straighten them? (without damaging the surfaces)?
Last edit: 22 May 2021 07:17 by martin_csr.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
22 May 2021 11:35
#848869
Not saying this is the issue, but some of the aftermarket pipes require a longer or shorter split collars.to make a good seal.  Have also read here and else where that the copper gaskets for some of the Suzuki bikes work better than those for the Kaw bikes.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • kawirider
22 May 2021 21:26
#848889
Did the mac exhaust for your son's bike accept the oem split collars?
  • 750 R1
  • 750 R1's Avatar
23 May 2021 17:07
#848917
  • Rick H.
  • Rick H.'s Avatar
24 May 2021 06:00
#848936
FYI, the Suzuki exhaust gaskets that were mentioned have a  gasket material in them that is sandwiched between copper.  I tried them on my KZ-1000 but they were too thick for me to get the exhaust nuts started.  They probably would have worked great but unless I install longer exhaust studs I will never know.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • gd4now
  • gd4now's Avatar
24 May 2021 07:44
#848941
Agree longer studs or shorter split collars would be a solution.
1977 KZ650 B1
