Kz440 kickstarter oil seal?
- Larithion
19 May 2021 13:49
Hi there. I have a bit of a Frankenstein bike, its a 79 kz400 with what I think is the engine from an 83 kz 440. Its leaking oil from the kickstart seal. I cant seem to track a replacement seal down
was wondering if anyone here would have a source for something like that or advice on how to resolve the problem.
ive tried z1 enterprises, johnnys vintage and partzilla to no joy.
Thanks in advance.
Thanks in advance.
Re: Kz440 kickstarter oil seal?
29 May 2021 10:06
bump
- Nerdy
29 May 2021 14:04
IIRC the kickstarter disappeared from the 440 in '81, so there wouldn't be one on an engine from an '83; this may explain why you haven't been able to find a seal. Why do you think the engine was swapped?
Conversely, the '79 KZ400 did have a kickstarter. You should be able to find that part number on Partzilla.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
29 May 2021 18:10
- Nebr_Rex
30 May 2021 20:33
KZ440 never had a kick start.
The early and late KZ400 use the same seal.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
31 May 2021 16:40
Also the shaft is the same size as the KZ650.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Larithion
11 Jun 2021 08:20
From what the previous owner told me, the engine was swapped by himself some time ago, and he somehow put the kickstarter in the 440 engine before he did the swap. I just got another 440 engine as well for a hundred bucks. I figure this one has some blow by anyway, might as well swap them out this weekend, and then rebuild the one with the kickstarter for experience and fun. I'll upload pics of the process at some point and try to figure out the exact engine via serial numbers.
I think i tracked down the right seal, through a local small shop owner, he has two kz400s and seems quite knowledgeable and friendly. Ill update as I go.
