KZ305 - 305CSR - GPz305 oil flow modification
- Injected
Re: KZ305 - 305CSR - GPz305 oil flow modification
29 Apr 2025 18:45 - 29 Apr 2025 18:50
Kawasaki put those oil line restrictions in a lot of their engines.
The 650/750 fours have them and the 900/1000 fours have them, some are not actual plugs but a purposeful reduction in the oil passage ID's in some spots as cast.
I recently saw this on the one side of the main oil line in the upper case of a 1000, and asked a expert if I should "open" up that hole and the guy just about had a heart attack
He went on to educate me that those restrictions are engineered to increase oil pressure at a measured spot away from the oil pump.
Obviously I did not do it.
1978 KZ650B2 modified project
Last edit: 29 Apr 2025 18:50 by Injected. Reason: info
The following user(s) said Thank You: sf4t7, Wookie58, kimchella, Matratt3
- Matratt3
- 1987 KZ305-B2
30 Apr 2025 01:12
It is good to know that this plug is not a artifact of this model motorcycle.
Since the bike is still apart I will punch the plug back out and flip it 180 degrees to obscure the passage like it was originally.
I'm disappointed I had hoped I was improving the bike so it didn't have the early failure blowing cranks as some have reported.
But delighted that you guys provided timely feedback while the bike was still apart so I can undo what I have done.
Appreciate you guys!
- ckahleer
30 Apr 2025 07:48
Does your 87 have an oil pressure indicator light? My 82 does not, which has always been a concern. There is a plug you remove to check oil pressure. I expected oil to spray out when the plug was removed, but it just kind of ozzed out. I suspect there is no oil pressure indicater on this bike because pressure is too low to activate an oil pressure switch.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Matratt3
- 1987 KZ305-B2
30 Apr 2025 07:55
Perhaps the cranks failures are because of the clogged oil strainers not mentioned in the preventative maintenance.
- Matratt3
- 1987 KZ305-B2
30 Apr 2025 08:50
No, no oil pressure indicator. Pretty basic, neutral light, hi beam light, tachometer and speed.
Soon to have a phone mount so I can use google maps however.
- 82KZ305Belt
01 May 2025 14:34That's a technological anomaly and not allowed. Get a map and compass like the rest of us.
Sure glad I wasn't smart enough to do the oil mod when I cleaned my strainer.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
- sf4t7
01 May 2025 22:11
And by the way, actually using the map is a sign of weakness...
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
