Valve shims
  • TerryK
  • TerryK's Avatar Topic Author
Valve shims
10 May 2021 16:40 - 10 May 2021 16:57
#848314
anyone know if 13mm (kz650/750) valve shims come in sizes thicker than 3.45mm?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 10 May 2021 16:57 by TerryK.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Valve shims
10 May 2021 17:01 - 10 May 2021 17:25
#848316
anyone know if 13mm (kz750) valve shims come in sizes thicker than 3.45mm?
No, 13mm shims max. 3,20 mm. You only can get 7.48 mm and 9.48 mm shims up to 3.50 mm thickness...
Last edit: 10 May 2021 17:25 by Scirocco.
  • Nessism
  • Nessism's Avatar
Re: Valve shims
10 May 2021 18:50
#848318
According to the factory 750 manual shims come in sizes between 3.20 - 2.00mm
