crankshaft bearing color codes
  • Kawnut
  • Kawnut's Avatar Topic Author
25 Mar 2021 15:32
#845504
Can anyone help me with the color codes on the crankshaft bearings for a 1982 Kawasaki GPZ 750? I am ready to install the crank & am missing a bearing (been torn down for months). I now want to replace all the crank (main) bearings (10) of them. Need to use stock size & I know the have stock & oversize. Color codes identify the size of the bearing & I can't seem to find the info to place an order, so I turned to my buddies in this forum.
Thanks in advance,
Danny Williamson (KZnut)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: crankshaft bearing color codes
25 Mar 2021 16:28
#845506
Here are the color codes Danny
  • Nessism
  • Nessism's Avatar
  • Away
25 Mar 2021 20:38
#845507
If you want to supplement Scirocco's info use the search function here using keyword "bearings" and User Daftrusty.  Daftrusty is the most knowledgable on the subject of 650/750 bearings on the forum that I know of.  Lots of threads on this subject.
