Turbo Charger
- just wont start
Turbo Charger
09 Mar 2021 13:07
undefined Hi everyone, Hopefully i can talk to Kawasaki turbo owners or people with know how on stripping a turbo charger.
Was on the final push of the restoration and decided before fitting the belly pan and fairings to change the oil again so i started it and let it idle a while but it had other ideas and started dripping oil from the exhaust joints. Clean oil and not burnt, i have read that GPZ turbos can loose oil because the turbo is sited low down especially if they need a rebuild or if the piston type ring has the gap to the bottom. Anyway i have pulled the manifold and turbo, no oil in the manifold by the way, have bought a rebuild kit and started to strip the turbo, its a Hitachi HT10-B. Taken off the exhaust side and taken out the large circlip from the boost side, my question is how to separate it, i thought it would come apart easily , hitting it with a rubber mallet, just will not come apart. Please am i missing something or not doing it correctly , its totally clean and revolves easily. Help !
- rangeroy
Re: Turbo Charger
10 Mar 2021 06:12
put your turbo in a box & send it to Charlie @ evergreen turbos in Florida
1977 z650
- riturbo
Re: Turbo Charger
10 Mar 2021 15:29 - 10 Mar 2021 15:34
Ya dont screw around with it send it to charle . Hes the go to guy for the 750 turbo bikes .Hes rebuillt two for me so far . It needs more then just parts .Needs machine work to get it back to specs . He does great work and is reasonable too . Heres some more info . Read through this thread and youll see what m talkng about .And while your at it might as well join the turbo site .
www.750turbo.com/forum/viewtopic.php?f=10&t=13416
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 10 Mar 2021 15:34 by riturbo.
- just wont start
Re: Turbo Charger
11 Mar 2021 08:21
Thanks for the great replies guys but does anybody know ? The unit is super clean and looks still to be new, i just want to check if the piston ring is installed correctly, no machining will be needed. cheers
- riturbo
Re: Turbo Charger
16 Mar 2021 06:11
Just so you know .These bikes will leak oil into the turbo if you let them sit to long . Ive got 6 turbos and two of them will do it f not run for a while . A lot of guys on the turbo site store theres with a 2x4 under the front tire . Also dont fill it to the top with oil. Just to the lower mark on the site glass . Your turbo might be fine . If I were you .I would clean it up and start it with the exhaust off and look and see if it leaks while running . Also check to see if theres any oil in the plenum. Theres a drain on the bottom .Pull that and see if it has any oil in there before you start it .
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: just wont start
- DFIGPZ
Re: Turbo Charger
16 Mar 2021 14:08
you know Kawasaki offered a revised oil level window for the 750 Turbo for this very problem
1984 750 Turbo
- just wont start
Re: Turbo Charger
25 Mar 2021 12:23
Hi thanks for the great tips, The turbo boost side was just held together by a really sticky grey ish grease, the unit turned out to be brand new so i just made sure the ring gaps were set to the top, i keep it on the side stand now after your wise wisdom, i have put in the manual amount of oil of 3.5 l, Have i to drain some off?
its about half way up the glass,
Regards
Regards
- just wont start
Re: Turbo Charger
25 Mar 2021 12:26
Hello, i didnt know that fact, so was the oiling a problem from the very start ?
Regards
Regards
