flywheel bolt comes loose
- nk140
Re: flywheel bolt comes loose
26 Feb 2021 13:04Mikaw wrote: Woodruff key?
These bikes don't have a woodruff. Would have solved my issue more than likely.
78 KZ750B
26 Feb 2021 16:05nk140 wrote:Mikaw wrote: Woodruff key?
I wasn’t sure, I had looked at Parts fishe and it didn’t appear to be one. Sure would have been a cure all. Within the process posted by Scirocco it mentioned cleaning the crank snout. I’d aslo check it for ridges that might restrict the flywheel/rotor from seating fully on the snout tapper.
26 Feb 2021 20:05
Red Lock Tight.
- nk140
01 Mar 2021 11:33SWest wrote: Red Lock Tight.
That is precisely what I used and let it sit for 24 hours before trying it after torqueing it again. Seems fine now. fingers crossed.
78 KZ750B
