kz900 turbo
- mkawasaki23
kz900 turbo
23 Feb 2021 13:10
I am building a kz900 turbo prostreet bike. I am getting ready to modify the oil gallery block . I have some old instructions from Mr Turbo that show where to drill the hole for the oil feed line and then remove the oil pressure switch and tap for 1/4 inch npt for an oil restrictor. The oil restrictor is basically a 1/4 pipe plug with a hole drilled through the center. I need to know what size the hole is. It doesn't say in the instructions...it just says don't mess with the size of the hole, it's been carefully calibrated . If anybody with a turbo bike knows or could check I would really appreciate it. Thanks
- zed1015
Re: kz900 turbo
24 Feb 2021 01:45 - 24 Feb 2021 01:46
The restrictor hole through the 1/4 NPT plug is 1/4 inch or 6.3mm ( 6mm will do )
Last edit: 24 Feb 2021 01:46 by zed1015.
- mkawasaki23
- thebuelligan
- tbski101
Re: kz900 turbo
15 Mar 2021 17:03
The hole size in the plug is 1/4in. if the turbo is a rajay turbo. If your using another brand the restriction may need to be a different size depending on the type of bearings in the turbo.
