Clutch question. 05 KZ1000P
  • ken19
  • ken19's Avatar Topic Author
02 Feb 2021 09:09 - 02 Feb 2021 09:10
#842833
Installed all new friction and metal plates. Soaked all in engine oil before installing. There is no oil in the engine at this time. Installed sprocket cover yesterday. Checked adjustment on cable and adjustment on cover. All Good. Clutch lever has 1/4 to 1/2 inch play. The new springs required a little more effort but seems okay.
Cannot turn wheel by hand with clutch pulled in. Put a block under wheel and turned engine over by hand. Clutch did slip,,, did not try to go over block. Release clutch, there was no slip. Could not test in 2nd gear or the rest as Kawasaki's neutral lock system will not allow an upshift. I did test all gear shifting after reassemble, spinning output shaft and it shifted flawlessly.
Questions for thought. Should I consider this normal,,, that as soon as oil starts splashing around with the engine running it will likely work fine (my thoughts) or should I remove cover, reinspect my work. There were 9 friction and 8 metal. Installed with friction first, then metal, ending with friction. These are standard Kawasaki parts.
Cannot see how I could bungle this up!
Last edit: 02 Feb 2021 09:10 by ken19.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Clutch question. 05 KZ1000P
02 Feb 2021 10:11
#842838
Give the engine a good heat cycle to oil,move and set all parts for around 15 minutes....
  • Dr. Gamma
  • Dr. Gamma's Avatar
02 Feb 2021 10:36 - 02 Feb 2021 10:50
#842842
1/4 to 1/2 of an inch play at clutch lever is way too much.
I believe free play at clutch lever should be more like an 1/8 of an inch.
1986 RG500G 2 stroke terror.
Last edit: 02 Feb 2021 10:50 by Dr. Gamma.
  • ken19
02 Feb 2021 10:51
#842844
Dr. Gamma wrote: 1/4 to 1/2 of an inch play at clutch lever is way too much.
I'll correct that and see if it helps....
  • ken19
02 Feb 2021 10:57
#842846
Scirocco wrote: Give the engine a good heat cycle to oil,move and set all parts for around 15 minutes....
That's what I am thinking. I have rebuilt engines but never have I had to change out the clutch plates. I changed these out because three of them were blued indicating extreme heat. A cop bike,,, likely abused. They sit on the side eating doughnuts and drinking pure caffeine then when a sucker passes too fast they fire it up,,, gun it once,,, then burn out. The oil probably never had a chance to circulate. lol...
  • Mikaw
  • Mikaw's Avatar
02 Feb 2021 11:04
#842848
Hope Rick H doesn’t see this. He might have a different accounting of the day in the life of a motor cop.
  • ken19
02 Feb 2021 11:58
#842849
It's something very scarce in this country today... humor.
