external oil line
  • aylabear19
  • aylabear19's Avatar Topic Author
external oil line
20 Jan 2021 13:07
#842076
i have a 78kz1000 with a 900 motor board out to 1325 , has a big block. I want to run external oil lines to the head as i have poor oil flow to the cams as it is. any ideas on where to source possibly a kit. any help or advice would be greatful. thanks.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: external oil line
20 Jan 2021 13:14
#842079
Welcome to KZRider
Never heard of a kit to do this.
Is the motor apart to plug oil galleries
  • 750 R1
  • 750 R1's Avatar
20 Jan 2021 14:54
#842086
aylabear19 wrote: i have a 78kz1000 with a 900 motor board out to 1325 , has a big block. I want to run external oil lines to the head as i have poor oil flow to the cams as it is. any ideas on where to source possibly a kit. any help or advice would be greatful. thanks.
I've never seen them for the big Kawasaki's but they have been made for the big GS Suzuki's for years, here's a few links, maybe you could modify one of these ?
The first link would possibly be the easiest to make work...
www.bbracingllc.com/GS1100-GS1150-Top-En...ler-Kit_p_63688.html
www.suzukiperformancespares.co.uk/produc...nd-oil-feed-kit/726/
store.schnitzracing.com/ward-top-end-oil...uzuki-gs1100-gs1150/
  • zed1015
  • zed1015's Avatar
20 Jan 2021 15:20
#842088
There are no off the shelf kits .
You will have to make your own using AN4 stainless braided hose.
Easy enough if you know what to do.
I've done a few and posted a thread on how to dry block the cases and run the lines which is somewhere on here.
  • TexasKZ
  • TexasKZ's Avatar
20 Jan 2021 15:35
#842089
zed1015 wrote: There are no off the shelf kits .
Seems like a good candidate for the FAQ / wiki.
  • JR
  • JR's Avatar
20 Jan 2021 20:19
#842103
Google dry block kzrider and you will find zeds thread
  • aylabear19
21 Jan 2021 12:37
#842135
Thanks I will look these up and let ye all know how I get on
