Gas leaking from behind front sprocket when MC on stand
- Johio
08 Jan 2021 04:31
Hello,
i moved my kz400 - 79 to another spot in the garage the other day and it suddenly started to leak gasoline.
I checked the tank, petcock, carburetors etc but couldnt find any leaks or wet spots.
Finally i saw where the dropd were coming from - behind, or next to the front sprocket. See picture.
The gasoline was coloured Light Brown so probably has been in contact with oil.
What has happened? Why is there gasoline leaking from the front sprocket?
What must i do? Split the engine?
Hope someone can help me.
Best regards
Best regards
- scubaanders
Re: Gas leaking from behind front sprocket when MC on stand
08 Jan 2021 06:03
Your float needles are not closing so fuel leaks in to the inlet, down In a cylinder and then down to the crankcase.
Remove the tank, check the fuel tap. Remove the carbs and clean the float seat. Drain the oil and change the oil filter.
Don't start the bike until this is done.
Brgds Anders
Brgds Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: Johio
08 Jan 2021 06:08 - 08 Jan 2021 06:10
It could be dripping from the #1 carb and running through the sprocket area.
Do the carbs have overflow or vent tubes that end close enough to the chain that fuel could travel along the chain?
Definitely check the oil level and sniff the oil for evidence of gasoline contamination. If the level is too high or you smell fuel in it, definitely change it and the filter before starting the engine.
Last edit: 08 Jan 2021 06:10 by TexasKZ.
- Johio
18 May 2021 09:40
Thank you so much for your replies.
Dont i need to change like a gasket or something between front sprocket axle and The crankhouse? Or is the oil thst much thicker so that it doesnt leak?
Br Johan
Br Johan
18 May 2021 12:20 - 18 May 2021 12:28
Howdy. The engine/sprocket cover (#24 in the diagram) is open to the air, so it isn't sealed. no gasket. The area behind there gets grungy from chain oil sling. dripping gasoline could be washing off some of the accumulated chain oil. The fuel is probably coming from the carburetors, but it shouldn't be too hard figure out for sure.
www.partzilla.com/catalog/kawasaki/motor...400-b2/engine-covers
Last edit: 18 May 2021 12:28 by martin_csr.
