Exhausts
- Ninja
Exhausts
07 Jan 2021 08:27
undefined Hi all
Just wondering what your thoughts are on are on exhausts, I've just fitted a pair of non standard silencers with light baffling, they suit the bike but obviously may alter the fuelling, are we talking back pressure, extra baffling or rejetting, can hunt for some originals but pricey,it was fitted with a Motad 4into 1 but didn't like the lopsided look, these were reasonably priced so didn't hit me hard.
- zed1015
Re: Exhausts
07 Jan 2021 09:19 - 07 Jan 2021 09:57
With lighter baffling there's a good chance you won't need to alter anything but if you do it will be to increase the main jet size slightly.
Last edit: 07 Jan 2021 09:57 by zed1015.
The following user(s) said Thank You: Ninja
Re: Exhausts
07 Jan 2021 09:42
Back pressure results when your exhaust outlet is smaller than the exhaust inlet, and is seldom the case. You can also have pressure waves that bounce back and forth inside the tube. They are caused by the rush of exhaust exiting the combustion chamber, travelling down the tube and returning to the exhaust valve. If the valve is open when the wave returns it will have an impact on engine performance, and because of this the engineer will design to have the wave return when the valve is closed. The baffle is used to reduce noise to an acceptable level. Changing the baffle will have an effect on noise, and will likely have an effect on engine performance, but it would be minor.
The following user(s) said Thank You: Mikaw, Ninja
Re: Exhausts
08 Jan 2021 17:36
Intake side changes, pods for example, have a dramatic effect on the jetting needs, whereas exhaust side mods don't cause nearly as many issues. In fact, a lot of header systems don't require rejetting at all if the stock airbox is still installed.
- F64
- 81-KZ440D2
Re: Exhausts
08 Jan 2021 23:55
Soooo many variables with exhaust changes.
I wouldn't worry unless your power band is much worse.
You may have shifted the rpm where you make your peak power.
Here's a rabbit hole for you.
81-KZ440-D2.
LIC, NY
LIC, NY
The following user(s) said Thank You: Dragbike_Mike, Ninja
